» Links |
07-07-2007
I am writing on the blackboard 100 times:
Always put the side stand down
This is the second time I have had to replace the clutch lever because I thought the side stand was down and as I got off bike it tipped over and bent it.
I would bet that the number one replacement part from Triumph is the clutch lever.
Scott
From Winston-Salem, North Carolina, USA
Think you can, Think you can't, either way you're right.
Formula Extreme Favorite Bike: My one-and-only '03 Bonne
Bummer! How about using the sidestand to shut the bike off? That might help you remember??
Those levers can't be cheap.
2003 790 (black, not Black) KARK'd, K&N Cones, Staintunes, 130/42 jets, 2.5 turns out, BC Superbars, CRG LS mirrors, Generic Rubber, 16t
God I love coffee.
07-08-2007
I think that is a good idea to just use the side stand to turn off engine. Then I just need to be sure I turn the key also and take it with me. As I get older these things seem to get more difficult.
Actually a new clutch lever only costs about 30.00 which seems like a bargain in the Triumph Parts World.
Scott
07-08-2007
You're right, 30 bucks ain't bad. That's surprising.
No worries, the Bonnie will keep you young at heart. :upthumb: Bent levers or speeding tickets, the money's gonna go somewhere.
God I love coffee.
07-16-2007
Supersport 400 Favorite Bike: 04 Bonnie Black
Posts: 86 Other Motorcycle: 76 Bonnie ( CHERRY )
Ya need a system. I turn off my bike the same way every time. Fuel off, check . Hit kill switch, check. Side Stand Down, double check.Solid ground for stand to land on check. Remove key. Step off walk a few feet and admire my bike and field questions on bike with on lookers.
The GWIAZ
07-16-2007
after a oops in the driveway, my clutch lever has a curl in the end. I like it, it fits using 3 fingers to pull the clutch and one to hold on. my old xs650 went down in some soft ground and broke the lever clear off. a bent one can still be used, a broke one is useless and in the back f the pickup.
cliff
07-16-2007
lever
A bunch of friends have been supporting Triumph w/ their new clutch levers.
They dont re-bend well @ all! I wonder if a litle heat from a torch might keep them from breaking when trying t ostraiten them? I bent mine a litle - same thing cept I inched the bike fwd while on the stand & it was draggin a little, enuff to NOT hold the bike up. I & the bike fell against a wood wall so I took most of the hit. Bent a little but still works & looks OK. Something so simple = so easy to forget!!
CAPT D
07-16-2007
Powerbike Favorite Bike: My Bonnie
Posts: 344 Other Motorcycle: My other Bonnie Extra Motorcycle: '98 FXD
Better than wacking the Napoleans...which I did...
Shoot safe, straight and often...
