CycleGear.comAdvanstarMotorcycleShowsMotorcycle.com Classifieds!TriumphPerformanceUSABikeBanditRacerPartsWholesaleMotorcycle.comSportbikeTrackGearSpringfield Armory
CycleGear.com
Old 07-10-2007   #11 (permalink)
I am not too sure Erwin ... i'll have to check, but I think it is the single.
I'll take another peek at Pat's jet calculator, but I seemed close last time. And apart from a little leanness through the mid range (3-4.5K), the dyno run showed me as being pretty good.
I am going to read up on all this carb stuff again at the weekend and see if I can't make sense of all these settings and how they come together.
Cheers; Paul.
You can take a look at my bike HERE!!
truebrit is offline   Reply With Quote
Old 07-10-2007   #12 (permalink)
Favorite Bike: 05 TBA
ErwinM's Avatar
Other Motorcycle: 1997 GT mountian bike :)
If its the single youre definetly close but slill a little lean. I would recomend at least 1 if not 2 shims with your current set up. Its very easy to do. Really.
You can find simple step by step instructions on
Pats site
[ This message was edited by: ErwinM on 2007-07-10 08:48 ]
Erwin
ErwinM is offline   Reply With Quote
Old 07-10-2007   #13 (permalink)
ErwinM's Avatar
Also thers pleanty of good folks willing to help in your area.
Check out the New Hampshire Rally
Erwin
Old 07-10-2007   #14 (permalink)
Erwin ...
A TBS needle (or 1 or 2 shims to the stock needle) would put me on a 130.5 mains ... spot on where I am now. So that confirms that I am on the lean side - accentuated in the mid-range.
However, my current hot start problem feels like it's choking up at idle/tickover and I need to understand what impact the mixture screws have throughout the rev-range. If I turn back a half or three quarter turns now, am I just leaning everything out higher in the range too? And if so, should I be swapping back to the 40 pilots and leaving the mixture put?
Cheers; Paul.
Old 07-10-2007   #15 (permalink)
ErwinM's Avatar
try the simple first. when the motors hot, pull the choke half way and see how it starts. And what is your idle set to when hot. I would tend to think that your idle circuit might be a bit rich at 3 3/4 turns. A 1/2 turn in on each might help and thats also simple to do.
Draw back is it might give you some popping on decel.
[ This message was edited by: ErwinM on 2007-07-10 10:35 ]
Erwin
Old 07-10-2007   #16 (permalink)
When I was having trouble starting the bike the other day Erwin, from cold (but ambient temp at 80F+) , it was really struggling to hold the idle. As soon as I touched the choke ... like 1/8" to 1/4" - it cut the engine immediately.
I read that as choking-up.
Since all the work was done last year, including the 42 pilots - she hasn't needed much choke in the cold - and very little if any as the season warms up.
So I am guessing that the extra turns on the mix have just pushed her into "rich at idle" in the warm ... sound feasible?
Cheers; Paul.
Old 07-10-2007   #17 (permalink)
ErwinM's Avatar
yes definetly! Those mixture screws need to be turned in. Sounds like we have come to an educated conclusion. Do you have a "D" tool?
Erwin
Old 07-13-2007   #18 (permalink)
Busy, busy, busy ...
Sorry for the delay in responding Erwin ...
... and no, I don't have the magic "D" tool
Time to get one, or get the replacement mix screws from NewSpeedmaster.com
Cheers; Paul.
Old 07-13-2007   #19 (permalink)
ErwinM's Avatar
Time to get D tool or get the replacement mix screws from NewSpeedmaster.com
I figured the tool was cheaper and easier to deal with. Just stick it in and start scewing in or out. :-D
Erwin
Old 07-14-2007   #20 (permalink)
Ok ... stupid question ...
Clockwise - richer or leaner?
Cheers; Paul.
hard starting warm engine viktorbgd Speed Triple Forum 47 03-09-2008 11:35 PM
2006 Sprint Hard Starting When WARM problem SoCalSprint Sprint Forum 2 07-25-2007 07:13 PM
Warm-weather starting billybob235 Twins Technical Talk 4 03-15-2007 06:29 PM
T140V Boyer problem - cutting out when warm Birles Classic, Vintage & Veteran 3 07-24-2005 03:09 PM
Fouled plugs = Rich gas or Electrical problem or Both? Trudie Classic, Vintage & Veteran 6 03-22-2005 01:26 AM
