Originally Posted by truebrit
Yep ... thats great dardoonk!! So you went for the 605A ... does that the air up and over your head/helmet or just off your chest? And does it use the universal 2-point h/bar mounts?
Cheers.
[ This message was edited by: truebrit on 2007-07-13 16:50 ]
It depends on what angle I put it at. I prefer a little more laid back look.
1- I think it's a bit sportier that way.
2- I knocks the wind off my chest and still takes most off my face.
When I stand it more upright, the air is definitely directed over my helmet, but I get a lot of buffetting as the deflected air feels like it wants to expand right where the top of my head is. Seems to strike right on top of the helmet and at 75 is so rough I can't even focus.
Problem solved when you lay the screen back some. I ride visor up quite often and have no problem the with the position you see in the pic.
Screen mounts solidly using only two handle bar mounts. It says it is 7/8" mount, but mine is actually a 1" mount with included spacers for the smaller bar.
Mount is a bit tricky to tighten and keep the screen dead center because it moves a bit when the bolts are torqued. Once you have it, your done & never have to adjust. You can remove it by removing the bolt at the handle bar clamp. The bolts near the screen don't need to come loose.
I've gotten this far in life by refusing to act more than half my age, and I intend on continuing this way.
My Photos
'05 America- Works' suspension, Freaked, D&D's, 150 mains, 42 pilots, TBS needles, 1 shim
