Did you remove the airpump? If not pull the tank check for the vacuum tubes leading to the pump, remove pump and spend 20cents at the auto store for rubber plugs for your carbs where the lines went to and you're all set.
! The dealership didn't take mine off when the AI and Preds were put on and she backfired between shifts and on motor braking. Hope that solves your prob.
 Mods:Predators/fork stabilizer/AI removed/Keihin CR-S carbs/RaceTech fork springs/Nology wires&coil/Iridium plugs/Traxxion emulators/LSL sliders & damper/Napolean mirrors/Monza fuel cap/19t front sprkt/flyscreen/Pazzo Levers/Ohlins 36PL shocks
