BikeBanditTriumphPerformanceUSAMotorcycle.com Classifieds!ShopTriumph.comSpringfield ArmoryRacerPartsWholesalebritishcustomsCycleGear.comSportbikeTrackGearMotorcycle.comAdvanstarMotorcycleShows
Annitori.com
Old 07-05-2007   #1 (permalink)
Hi guys
I thinking of locating the ignition swith to the left side cover, has any one done this, if so, is there enough wire, and could you post picks of what it looks like in the cover.
Cheers
Bugsy
Bugsy-12GSRC is offline   Reply With Quote
Old 07-05-2007   #2 (permalink)
Mancha's Avatar
Thrux-ton-up has done it. Check his albums. My memory is that there is NOT enough wire. You will certainly need to unwrap elements of the wiring loom, and then splice in some bits to provide enough length.
I would be unwilling to do this simply because it would now be difficult to take off the sidecover.
Ogle my bike here.
Mancha is offline   Reply With Quote
Old 07-05-2007   #3 (permalink)
Favorite Bike: 2006 Thruxton "Zoe"
mr_badda_bing's Avatar
I am not sure how hard this would be, I have seen some that have moved them to the steering tree, I have moved mine to the rightside on the bike at the headlamp side.
[ This message was edited by: mr_badda_bing on 2007-07-05 16:05 ]
2006 Thruxton - Zoe Yellowbike
125 main jets, 42 pilots, 1 shims, 2 turns, HARK (homemade airbox removal kit) EMGO Reverse Cones, 17T sprocket. 4700 Feet Above Sea Level
mr_badda_bing is offline   Reply With Quote
Old 07-05-2007   #4 (permalink)
Thanks for the replies, not sure how or what i will do with it, i've seen a couple of pics with it moved to the handle bar clamps, but i think it makes it look bulky
Old 07-05-2007   #5 (permalink)
TCL
Favorite Bike: Triumph Bonneville T-100
TCL's Avatar
Other Motorcycle: 1977 Honda CB400F
I put mine in the right side cover. You have to cut the wiring loom to about halfway down the tank to have enough free wire to reach the cover. If I remember, I had to cut a wire and splice it as well. I have the full shop manual with the wiring diagrams, which helped calm any concerns I had about cutting the wrong wire. Much easier to start the bike now, and looks cool as well.
Death or Glory
TCL is offline   Reply With Quote
Old 07-05-2007   #6 (permalink)
I did this little mod moving it to the right side cover - a few nylon spacers from the hardware store and some longer stainless bolts for mounting are all that is needed. I cut the hole for the switch with a hole saw, drilled the 2 mounts, and then had the cover pained. I had to splice 2 wires (made longer) to get it to reach - although all the rest or the wire will light you move it anywhere you like.
Heres what it looks like after paint.
before painting.
http://www.triumphrat.net/memberalbums/data/500/thumbs/dragon1.jpg
John W.
  • 04 Thruxton – Graphite & Opal
  • 06 T100 – Black & Red
  • 05 T100 - Black & Opal - Project Bike
  • 51 T100 – Silver & Black
Thrux-ton-up is offline   Reply With Quote
Old 07-05-2007   #7 (permalink)
bonnieblackinfl's Avatar
Bonneville Performance has a relocation kit that uses a smaller ignition unit. Go to the website and take a look if you prefer a kit.
Greg
bonnieblackinfl is offline   Reply With Quote
Old 07-05-2007   #8 (permalink)
Kool thanks guys, those pics look kool
Bugsy
Blinker relocation Whitehurst Club Cafe 4 12-11-2006 10:16 PM
Sprint ST seat key relocation blurb Suncoast Sprint Forum 4 12-09-2006 12:45 PM
key relocation skeeterbarnes Twins Talk 2 07-05-2006 10:36 PM
insert key - turn key - nothing convict Twins Talk 3 05-08-2006 08:40 AM
Fuesbox Relocation Doyle Hinckley Classic Triples 8 04-10-2006 09:24 PM
