TriumphPerformanceUSABikeBanditRacerPartsWholesaleAnnitori DistributingSpringfield ArmoryTrident-Exhausts.comCycleGear.combritishcustomsMotorcycle.comAdvanstarMotorcycleShows
SportbikeTrackGear
Old 07-04-2007   #11 (permalink)
Zansongs's Avatar
Oh, Wrench, ride, and then booze. *****, I knew I had it wrong
My Pony is a B/W 07 T100
Check out my music
www.myspace.com/zancantwell
www.soundclick.com/zancantwell
Zansongs is offline   Reply With Quote
Old 07-04-2007   #12 (permalink)
Favorite Bike: 05 Bonneville T100 B/W
wenzel850's Avatar
Sounds to me like the carbs are out of sync.
Quentin
"01-20-2009 I can't wait"
wenzel850 is offline   Reply With Quote
Old 07-04-2007   #13 (permalink)
Mine started doing the same think a while asgo. I pulled & resealed the rubber boots. Runs fine now. It also wouldnt idle worth a s*** till it really got hot. Those boots taske a lot of heat & can leak w/o knnowing it. As said check the carb boot clamps as WELL! & good luck. :???: :hammer:
CAPT D
Old 07-04-2007   #14 (permalink)
Favorite Bike: Bonneville 750cc T140V
Other Motorcycle: Hinkley fake Bonnie T100
Give it the dealer, it's still under warranty.
English_Spanner is offline   Reply With Quote
Old 07-04-2007   #15 (permalink)
Favorite Bike: My one-and-only '03 Bonne
pabonne's Avatar
that's Rolling Rock for you boys
Sadly, Rolling Rock was bought out and is no longer brewed in Latrobe. There are lots of other good PA beers though.
2003 790 (black, not Black) KARK'd, K&N Cones, Staintunes, 130/42 jets, 2.5 turns out, BC Superbars, CRG LS mirrors, Generic Rubber, 16t
God I love coffee.
pabonne is offline   Reply With Quote
Old 07-04-2007   #16 (permalink)
I’m sorry that I don’t have any solutions that haven’t already been suggested, but I REALLY want to know the answer to this brain teaser.
SlowPocono is offline   Reply With Quote
Old 07-04-2007   #17 (permalink)
One other possibility,
Check the throttle position sensor, the black plug thing on the right side of the carbs. Make sure it's connected or the ignition module will default to wide open throttle ignition advance settings.
-edit-
Thinking about it, it would make it run and idle rough, which you say it doesn't, so maybe it's not the TPS.
[ This message was edited by: Kurtis on 2007-07-04 12:33 ]
Kurtis is offline   Reply With Quote
Old 07-04-2007   #18 (permalink)
Favorite Bike: Velocette Thruxton
Thruxton's Avatar
Other Motorcycle: BMW R1100RS
Extra Motorcycle: 67 BMW R60, with sidecar
Check the cables going to the carburetors.
If one is longer than the other, it would mean that one cylinder is working harder than the other and the bike would virtually be running on one cylinder.
The more throttle you give, the greater the vibration.
At an idle it would appear to be running perfectly.
Crazy Old Bastard.
62 years old and I still don't know what I want to be when I grow up.
Loud pipes are rude and inconsiderate.
Thruxton is offline   Reply With Quote
Old 07-04-2007   #19 (permalink)
Favorite Bike: '06 T100
Cheers for all the replies fellas, it definitely doesn't seem to be something obvious though. I tried to rule out all the obvious things already. As soon as it started doing this last weekend the first thing I did was hook up the ol' mercury gauge and check the carbs. They were only off by a couple of graduations on the scale but I tweaked it back into line anyway. No change.
Then I checked the plugs and they were both looking pretty good. Nice chocolate brown, and firing.
If this were an older bike acting this way, I would be looking to check/adjust the timing because that would help explain both the knocking and poor fuel economy. Not sure if that would cause the vibration. Unfortunately it's an electronic ignition which I really know nothing about. As far as I know there is nothing to adjust. Is the crank pickup adjustable? could that have loostned up and be causing my problems??
I will look at the Carb boots for any leaks, but you guys said that you had trouble idling when you had leaky boots. Mine is idling beautifully. It just fires right up and purrs right along. Till the rpm's start to climb that is and the vibration kicks in.
It is still under warranty so I will just take it to the dealer when I get a chance, but that wont be till saturday because they're 2 hours away and it takes half a day to truck the bike up there. It also means I'll be missing out on my bike for at least a week or two. If it needs any parts that could be even longer. I'll keep trying to figure it out on my own for the rest of the week.
Some people are a lot like Slinkys.
Not really good for anything, but bring a smile to your face when you push them down the stairs.
Big_Rick is offline   Reply With Quote
Old 07-04-2007   #20 (permalink)
Retired Legend
sweatmachine's Avatar
maybe a clogged jet?
Unusual Cover Versions Of Fav Songs BorgCymru Biker Hang-Out 52 02-02-2008 04:57 PM
an unusual newbie bode61 Sprint Forum 19 10-22-2007 02:40 PM
unusual clutch action Eddie T3 Sport / Touring Forum 6 02-07-2006 01:41 PM
An unusual Touring question. Smudger075 Sprint Forum 9 07-13-2005 07:41 PM
Unusual part needed desertrider Twins Talk 0 06-12-2005 01:28 PM
