On the 03's, the tubes for the pilot jets are plugged with a thin aluminum disk. Is that what you're seeing? If so, you'll need to drill a small hole into the disk, run a screw in, and then gently pull the plug out.
2003 790 (black, not Black) KARK'd, K&N Cones, Staintunes, 130/42 jets, 2.5 turns out, BC Superbars, CRG LS mirrors, Generic Rubber, 16t
Why? Too many H-D's.
