» Links |
07-03-2007
Formula Extreme Favorite Bike: 2006 Thruxton "Zoe"
I am wondering if anyone has any information on adding a power outlet to the Thruxton. I have a GPS that I would like to power (plus now and then the Sirius Satellite receiver).
Is the power outlet that Triumph sells a normal 12V plug or is it a funky sized one that would need an adapter?
Is it easier to go with the Triumph or go find an aftermarket 12V and mount it?
Will Batman ever escape from the clutches of.....
wait, wrong forum for that one.
Thanks!
2006 Thruxton - Zoe Yellowbike
125 main jets, 42 pilots, 1 shims, 2 turns, HARK (homemade airbox removal kit) EMGO Reverse Cones, 17T sprocket. 4700 Feet Above Sea Level
SuperSport Favorite Bike: 2001 Bonneville (cafe)
Posts: 1,223 Other Motorcycle: 2003 Honda XR650L Extra Motorcycle: 2008 Suzuki V-Strom 650
The Triumph accessory socket is a 12v BMW-style outlet -- just get an adapter cable to go with it (not expensive). The accessory socket is easy to install, and it's nice because it tucks out of the way and has a spring-loaded cover to keep it clean.
--mark
Bennington Triumph Bash
Bennington, VT May 29-31, 2009
Do you keep one bullet left for yourself, for when it's all over and done?
07-03-2007
Thanks for the info. I cannot find any pictures of it anywhere. I was not sure if I could use an aftermarket one for vehicles or not.
07-03-2007
You probably could, but the installation wouldn't be anywhere near as clean. There's already a screw hole in place for the official accessory socket, as well as a plug on the wiring harness that connects to it.
--mark
07-03-2007
Formula Extreme Favorite Bike: 2005 Aegean Blue Triumph Bonneville
Posts: 605 Other Motorcycle: 2005 Ice Mint Green Genuine Stella
Why not use a Yuasa / Battery Tender style plug? You'll have to make (or buy) an adapter, but they're super cheap ($6), tiny (just a flat two-prong plug), and can tuck neatly under the seat when not in use. Also, it's likely that any heated clothing you might later choose to buy would have this style of plug. If you need to plug in a charger, you'll already have the right plug. Plug in clothing? The right plug. Plug in other things? Adapters are small and can be taken off when not in use. It attaches directly to the battery on its own pigtail with a separate fuse, so you won't be adding any draw to the factory wiring.
2005 Aegean Blue Bonneville - stock, Ikon front fork springs
07-04-2007
I was about to ask the same question about power outlets.
Where does this plug go, and does anyone have a picture of it installed (triumph).
What do these adaptors look like?
I have a battery tender pigtail, but my GPS and cell phone power cables are USB type and I don't want to cut it up, it gets used in the car, too.
-Ben
http://www.bendavanza.com
07-04-2007
World SuperBike Favorite Bike: 2005 Bonneville T-100
Dang....when I read the topic....I was thinking this was going to be story more along the lines of a Girls Gone Wild episode.....I'm so disappointed now....
[ This message was edited by: Panthermark on 2007-07-04 18:04 ]
