Motorcycle.comBikeBanditAdvanstarMotorcycleShows
Old 07-02-2007   #1 (permalink)
usnen2
I bought my wife an 02 bonneville this year. I've been riding quite a while but this is her first bike. I really like it but the front brake doesn't seem quite right to me. I usually ride a BMW r1100r which has excellent brakes and switching to the bonneville is a big difference. If I give a good squeeze on the brake lever of the bonnie I can pull the lever back till it touches the grip. Should I be able to do this? It just seems too spongy to me. I manually bled the brakes and it didn't make any real difference. Do you have to use a power bleeder for these and do you think some braided steel brake lines would make and improvement?
Thanks in advance for your input
Old 07-02-2007   #2 (permalink)
Favorite Bike: 05 Black Speedmaster
I believe you already have the braided line but the lever should not go to the grip, stubborn air bubble at the master cyl ?
Old 07-02-2007   #3 (permalink)
either air in the system or possibly completely worn down pads..I guess you checked them?
G
I just wanted to ride
Old 07-02-2007   #4 (permalink)
Bleed the brakes. Probably has never been done. If your pads are worn but not worn out the fluid level will have dropped. Unless it is too low (then you may have another problem), do not be tempted to fill the reservoir to the top. Kind of eyeball where the fluid is and add as you bleed. When done you should have the same level or just slightly more. If you do fill the reservoirs up, when you push the piston back in to replace the pads,well,...get ready for a big mess.
Jimi_X is offline   Reply With Quote
Old 07-02-2007   #5 (permalink)
Favorite Bike: 2001 Bonneville (cafe)
Other Motorcycle: 2003 Honda XR650L
Extra Motorcycle: 2008 Suzuki V-Strom 650
My front brakes are spongy as well, even after replacing the pads, brake lines, and fluid. When they heat up they get firmer, and they're never so soft that I can pull the lever all the way down to the grip, but still...
I've begun to think that older-model-year New Bonnevilles simply have slightly spongy front brakes.
--mark
Bennington Triumph Bash
Bennington, VT May 30-June 1, 2008
Thanks to all who attended!
Do you keep one bullet left for yourself, for when it's all over and done?
markbvt is offline   Reply With Quote
Old 07-02-2007   #6 (permalink)
mecscc's Avatar
Good advice all. Your wife's Bonnie's front brake is definitely NOT normal, and is dangerous. Air bubble, worn pads, possible, but unlikely, bad brake line that has a bad wall allowing it to expand. Could be any of those things, but it is not right.
Monte
Monte
"The Old Ohio Preacher Man"
Old 07-02-2007   #7 (permalink)
usnen2
All-
Thanks very much for the info- looks like I've got some work to do.
Front end is too soft Palle Sprint Forum 12 06-01-2007 04:04 PM
TT600 front forks WAY to soft?? TT600stunts Triumph SuperSports 3 04-09-2007 03:00 PM
Soft brakes and brake fluid – avoid DOT 5 PaloAlto Sprint Forum 6 03-30-2007 04:54 PM
soft trident front end Wanny T3 Sport / Touring Forum 2 11-16-2005 07:25 AM
Front brake goes soft over day on track karter257 Club Cafe 10 10-24-2005 01:17 PM
