I noticed a few drops of oily looking stuff under my bike this weekend, so I started investigating- the fluid itself was a sort of brown and black, so I was reluctant to immediately identify it as either oil or chain gunk. I cleaned everything up and worked to isolate the problem, and it appears that whatever it is is NOT coming from the filter, front sprocket, or the oil pressure sending unit.
After a cleaning and then a ride, it seems like most of it is collecting on or around the two cables that run under the bike along the frame (on the right). The fluid is sitting on the point where those cables turn upwards just by the front sprocket.
For now I'm adopting a wait and see attitude, but I'm thinking that my chain is just throwing a lot of stuff off right now- maybe I got a little too much lube on it last time. In fact, I first noticed the issue immediately after washing the bike, and lubing the chain. The thing that's concerning me is that it's still coming off, even a couple of days later. Is there another spot where oil could be leaking besides the places I checked?
