RacerPartsWholesaleMotorcycle.comTrident-Exhausts.comMotorcycle.com Classifieds!Annitori DistributingSpringfield ArmoryAdvanstarMotorcycleShowsShopTriumph.comTriumphPerformanceUSA
Old 07-01-2007   #1 (permalink)
webonnielad's Avatar
Hi guys
Has anyone fitted the NH rear sets?
I learnt froward to get out the wind behind my dart screen the other day and found a place with no wind.
So now I'm thinking ace bars, rear sets and a credit limit increase.
However my real question is.
Does it change the gear shifting?
In the ol' days when we made our own, you had to drill the OEM gear leaver to run the linkage off of it.
This would mean on todays bikes that the gear changes would be 1 up 4 down.
Would this be the case now?
Jon (UK)
webonnielad is offline   Reply With Quote
Old 07-01-2007   #2 (permalink)
Retired Legend
sweatmachine's Avatar
I have them and they're great. Shifting is the same as stock, 1 down 4 up. It has also improved the feel of the shifting.
I have the M bars and the NH rearsets and it's a good combination. I have nothing but good things to say about the NH rearsets.
Go for it!
you can check out a picture of my bike in the link in my signature below.
[ This message was edited by: sweatmachine on 2007-07-01 11:32 ]
NH Rearsets Riven Twins Technical Talk 2 03-01-2007 11:42 PM
Rearsets MumblyJoe Twins Technical Talk 21 09-15-2006 04:28 AM
rearsets jnicosia Speed Triple Forum 11 06-14-2006 11:27 PM
rearsets jnicosia Speed Triple Forum 9 04-19-2006 10:34 AM
rearsets jnicosia Speed Triple Forum 30 01-24-2006 11:34 PM
