» Links |
06-28-2007
Newbie
Anyone ever get any slight oil seepage out of the cylinder head gasket on a 2004 Bonnie?
Site Supporter Retired Legend Favorite Bike: 904cc Bonnie w/magwheels
you're thinking cam cover gasket (not cylinder head), and yes it is very common.
06-28-2007
Newbie
Thanks for the clarification! Do I need to do anything right away or worry about it?
06-28-2007
Common? I thought these new Bonnies weren't supposed to leak...
'06 Bonnie Black - AI and snorkel removed, TORs, K&N, IKON rear shocks, Hagon fork springs, Pingel, Tach added, K&Q seat, centerstand, Lucas Style Sport lights
06-28-2007
HalfPipe,
Depends on how serious the leak is. I've dealt with this issue a couple of times (as have many on this board) and I think you should just keep an eye on the sight glass. If the level gets too low (or if the seepage increases) I would go ahead and re-install the gasket. IMPORTANT: Use a torque wrench for the cam cover bolts! (10 nms)
Some folks use RTV on the gasket to get a better seal. I replaced mine with a new gasket, no RTV, and it's holding up just fine.
Have you ever stopped to think about what rats do for fun?
- Shane MacGowan
Never Forget Chickenman.
06-28-2007
Half -
The oil leak you have is nothing to be worried about - usually an easy fix (often a bad gasket or lose cam cover bolts) and covered by the warranty. Keep an eye on the oil level, though the leak is probably that minute that you won't see a measurable oil loss in the sight glass.
Good to see a fellow snowboard instructor on this forum!
"Well, everybody likes motorcycles... to some degree."
- Bob Dylan
'05 Thruxton, Epco, RaceTech fork springs & cartridge emulators, YSS Shocks, Unifilter, snorkel out, 130 mains, 40 pilot, 1 shim, pilot screw 3 turns, turtle wax
06-28-2007
Formula Extreme Favorite Bike: Tiger 1050
Posts: 442 Other Motorcycle: Honda Transalp
Mine weeped a bit from new - discovered the cam cover bolts were only finger tight. Tweaked them up a bit and never had a leak since.
Time flies like an arrow...
Fruit flies like bananas
06-28-2007
Powerbike Favorite Bike: Bonneville 750cc T140V
Posts: 355 Other Motorcycle: Hinkley fake Bonnie T100
If you believe the salesman.......
Not supposed to......
but... OH YES THEY DO!!!
[ This message was edited by: English_Spanner on 2007-06-28 12:03 ]
06-28-2007
[/quote]
[/quote]
I wasn't listening to the dealership I was reading the responses and posts on the forums here.. You know, great classic style but none of the annoying oil leaks! Modern technology, etc, etc.
Maybe this forum is full of Triumph salesmen, huh?
:wink:
I've got a HD up for sale but maybe I should reconsider? No oil leaks experienced in 7 years of owning 2 HD's.
06-28-2007
Newbie
Thanks all for the info. Glad to know it would be a warranty issue if it comes to that. I check the oil level in the glass regularly anyway.
By the way, '05 Truxter, where do you teach? I'm up in Okemo, VT.
