Motorcycle.comBikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.com
BikeBandit
Old 06-27-2007   #1 (permalink)
Favorite Bike: 2008 Triumph Bonneville
OhioSpeedmaster's Avatar
One of my more lofty mods ( I hope ) is going to be integrating a mini speedometer into the headlight bucket.
I figure the two bigget issues I'm going to deal with are moving the wire looms enough to make room for it as well as making sure I have a water tight fit.
I'm curious as to whether anyone might think I'll have a heat issue generated from the speedometer and headlight that might cause me some problems....
I certainly would appreciate any input the great minds of this site might have!
OhioSpeedmaster is offline   Reply With Quote
Old 06-27-2007   #2 (permalink)
Favorite Bike: Definitely my 2007 Black
Hedge's Avatar
Very ambitious! Good Luck
Proud to be an American Infidel!
http://www.thingsididilastnight.com/
Hedge is offline   Reply With Quote
Old 06-27-2007   #3 (permalink)
Favorite Bike: 2007 Bonnie Black
xardoz's Avatar
I would think the easiest thing to do would be to get a tube that is just larger than the speedo to act as a housing. Find an angle that works so you can see the speedo face and weld the tube to the headlight bucket.
kinda like this old Old Honda Bucket:
only round, not triangular. :razz:
xardoz is offline   Reply With Quote
Old 06-27-2007   #4 (permalink)
I don't think you'll have a problem with heat, but I'll be curious to see how you route the speedo cable thru the housing.
There's a lotta wires inside that thing..
Hogtied is offline   Reply With Quote
Old 06-27-2007   #5 (permalink)
Retired Legend
sweatmachine's Avatar
here's what's inside the headlight:
Old 06-27-2007   #6 (permalink)
Mancha's Avatar
A number of people have proven that you can move wires elsewhere if it's important enough to you. I think that you'll have an easier time with your mini speedo plan than with the fullsize speedo. I suspect the hole will definately have to be toward the back of the bucket though, else the speedo will bump into the light element. You might want to make a small hole in the bottom of the bucket to pass the speedo cable through. Buy one of those rubber grommets from the hardware/auto store to fill the hole. Finally, you can tape some heat shield material around the speedo if you're worried about heat buildup. Good luck. I'll be interested to see how it turns out.
Ogle my bike here.
Mancha is offline   Reply With Quote
Old 06-28-2007   #7 (permalink)
Favorite Bike: 2005 Bonneville Black
i have been thinking about doing this...if done right it will look bad ass.
Any reason you cant get an early headlight assembly / speedo and mod it to your bike. That seems easier then starting from scratch.
2005 Bonni Black; Reverse Cones, Pods, No AI, 145, 42, Thrux Needles, 1.75 Turns Out, Iridium's, EBC Brakes, Speed-Bleeders, and a pile of stock parts.
SCL18 is offline   Reply With Quote
Old 07-11-2007   #8 (permalink)
Old BMW Headlight/Speedo
or
Old Soviet Union BMW
Old 09-26-2007   #9 (permalink)
Well i bit the bullet and bought a vintage BMW Airhead Headlight Bucket w/speedo....now comes the fun part.
Anyone know where to get Vintage BMW parts (12v Halogen Headlight Assy)?
Thanks,
Steve
Headlight Bucket Mess Loxpump Twins Technical Talk 26 01-21-2008 12:05 AM
Headlight Bucket ready to go... REVOLT Twins Technical Talk 8 12-24-2007 09:34 PM
idiot lights in the headlight bucket! sweatmachine Twins Technical Talk 11 12-04-2007 12:11 PM
aftermarket headlight bucket? elephant_rider Twins Technical Talk 1 07-12-2007 10:05 PM
Headlight Bucket Swap derek985 Twins Technical Talk 4 07-02-2006 11:44 AM
