britishcustomsCycleGear.comAdvanstarMotorcycleShowsRacerPartsWholesaleShopTriumph.comTrident-Exhausts.comMotorcycle.com Classifieds!Annitori DistributingMotorcycle.comBikeBanditSportbikeTrackGear
CycleGear.com
Old 06-26-2007   #1 (permalink)
Favorite Bike: Do you have to ask?
TB-T100's Avatar
Other Motorcycle: Unfortunately not
Extra Motorcycle: Would love a Speed Triple
The brake-pedal on my Bonnie got some scratches from a little mishap earlier this Summer. I assume that it would be possible to sand it to good condition again, but don't know what grade sandpaper I should use. The assumption is that it would be best to use atleast two, maybe three different grades (one to get the scratches out, and one or two to get the stock finish back.
Can anybody tell me what would be two or three good grades to use, please?
Also, would this apply to all aluminum parts on the bike?
'04 T100 Black and White (because that is the only colour-combination to wear with a dinner jacket)
AI removed, TORS
rebuilt front (valves, springs, etc), Öhlins shocks
engine dresser bars, grab rail, flyscreen, Triumph leather panniers and tank bag
TB-T100 is offline   Reply With Quote
Old 06-26-2007   #2 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
600, 800, and 1000 for a final. Make certain to keep the part wet.
Hated By All....cause thats just how it is.
SCCTrim is offline   Reply With Quote
Old 06-26-2007   #3 (permalink)
Depending on how scratched it is, you may be best off starting with a file, then I would do wet or dry 220, 400, 600, 800, and then buff with a dremel and some metal polish. That's how I did it and it looks lovely.
2005 T100
Old 06-27-2007   #4 (permalink)
TB-T100's Avatar
Thanks guys.
AI removed, TORS
Old 06-27-2007   #5 (permalink)
Aluminum is a wonderful metal to work with, hook in to it, don't be shy, it is very forgiving.
Worry about getting all the marks out first concentrating on getting the 'grain' ar scratches all going in one direction and then work your way through the wet and dry as described.
If you want to shortcut the process -
If you have a dremel you are laughing if not go to a hardware store and pick up a sanding flap wheel for your drill.
Or if you have a buffing wheel for your grinder you can generally remove any scratches in alloys just with the wheel and a bit of cutting compound
Blackjacks '07 T100
  • Raask Minizoom Rak Straight
  • NARK
  • AI Removed
  • Procom ignitor
  • Thruxton Front Guard
  • D9 Layflat
  • CRS Carbs - 120 main, 60 Pilot, 2 Turns, 2 down on Needle Clip (7 Clip Needle), 14mm Float height
  • + Other assorted bits and pieces
Blackjack is offline   Reply With Quote
Old 06-27-2007   #6 (permalink)
TB-T100's Avatar
I do have a Dremel. Would the sanding band 432 be way too coarse for first-round?
AI removed, TORS
aluminum intake apollyun Twins Technical Talk 10 12-04-2007 04:42 AM
Wet Sanding... Surferjo Club Cafe 5 02-13-2007 06:22 PM
polishing aluminum dazco Twins Technical Talk 8 12-09-2006 11:22 PM
Polishing the Aluminum IamNeighbordave Modifications & Workshop Talk 8 03-17-2006 09:55 AM
Polishing the aluminum.... IamNeighbordave Hinckley Classic Triples 6 02-16-2006 06:34 PM
