ShopTriumph.comTrident-Exhausts.comBikeBanditbritishcustomsSportbikeTrackGearAdvanstarMotorcycleShowsTriumphPerformanceUSASpringfield ArmoryRacerPartsWholesaleCycleGear.comMotorcycle.com
CycleGear.com
Old 06-26-2007   #1 (permalink)
After getting some great advice from this forum, I checked my plugs and it seems that the bike is running a bit rich (but it only appeared on one of the plugs)
So, I ordered the infamous "D" shaped tool. Now I just need to figure out where to use it. Where exactly is the fuel/air mixture screw?
Thanks.
2005 Bonnie Black
jcline8 is offline   Reply With Quote
Old 06-26-2007   #2 (permalink)
Retired Legend
sweatmachine's Avatar
on the bottom of the carbs (on the bottom of the float bowls) about dead center, just behind the 2 wires for the carb heaters. Just stick it in! It's the only hole it fits into.
Old 06-26-2007   #3 (permalink)
The D tool goes right where the brass knurled knob is on this photo. This is NewBonneville's replacement idle mix screws a with knob so no tool is needed. The LH idle mix screw is in exactly the same place on the LH carb:
2005 T100
Old 06-26-2007   #4 (permalink)
meatwagon's Avatar
as deb said.Bear in mind that the D screws ONLY affect the idle circuit mix,IE closed throttle .
Get it on,get it up,keep the beat
and RIDE WITH ZEKE
BIR #132
TonUp Club San Diego
meatwagon is offline   Reply With Quote
Old 06-26-2007   #5 (permalink)
Now, my understanding is that I will need to back it off about 1/4 turn. I assume this is on the Cyl that is running rich, right?
I am running no snorkel or restricter plate, Unifilter, Thruxton pipes with a baffelectomy and a 1 1/4 inch hole drilled in the plate. Jets were just changed to 125/42 with stock needles and no shims (I believe). The shop took care of the rejetting.
I notice that there is a slight hesitation on take off. It runs like a scalded dog when I really roll on the throttle.
Any advice is appreciated.
2005 Bonnie Black
Old 06-26-2007   #6 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
You may have it backwards...backing off to me means unscrewing a right-handed screw and that will make the pilot mixture richer. Tightening the screw will make the mixture leaner. With the 42 pilot jets, I would turn both pilot screws in until they bottom and then turn em out one turn and see how it runs. I really believe with your setup on a 790, you would be better off with the stock 40 pilot jets.
Larry
Larry
Fuel/Air mix question pbcurran Club Cafe 13 10-20-2007 08:49 PM
Tech question about air/fuel screw adjustment. 2112 Twins Technical Talk 4 06-09-2007 11:34 PM
Speedmaster Make the air/fuel mixture richer Slowgo Twins Talk 2 10-28-2005 02:08 AM
mikuni air mixture screw pmillica Hinckley Classic Triples 2 10-17-2005 01:23 AM
Air/Fuel Mixture Adjustment triumph2000 Hinckley Classic Triples 2 08-26-2005 04:02 AM
