Trident-Exhausts.comAdvanstarMotorcycleShowsbritishcustomsBikeBanditAnnitori DistributingSportbikeTrackGearRacerPartsWholesaleTriumphPerformanceUSAShopTriumph.comMotorcycle.com Classifieds!Motorcycle.com
Old 06-26-2007   #1 (permalink)
as far as i can tell, it's the rear brake [hydraulic] switch.
has anyone replaced one of these ? thanks, tim.
wrong36 is offline   Reply With Quote
Old 06-26-2007   #2 (permalink)
Sprint_Dude's Avatar
Yep. Mine too. Just had mine replaced last week. It was covered by the warranty. Switch went bad.
If it wern't for the gutter, my mind would be homeless.
BIR #203
Sprint_Dude is offline   Reply With Quote
Old 06-26-2007   #3 (permalink)
Mine's gone too. Iv'e removed the connector till I get a replacement.The front brake also triggers the light.
redwood is offline   Reply With Quote
Old 06-26-2007   #4 (permalink)
Have you guys tried adjusting the rear switch so it's off with no pedal pressure? The switch is threaded so the on/off point can be set.
McQueen278 is offline   Reply With Quote
Old 06-26-2007   #5 (permalink)
hmmmm, doesn't seem very adjustable... as soon as you loosen it up, brake-fluid starts to come out. there's no pressure on the rear brake, how would you adjust it ?
where's the best place to order this part ?
my nearest dealer needs to order it and it'll take 3 days.
NB FEK installed, brake light works no running light pbcurran Club Cafe 9 10-25-2007 03:20 PM
Brake light & Headlight out at same time? GParks Twins Technical Talk 4 08-12-2007 03:42 PM
Advice sought re frame sliders and tail/brake light upgrades for 2000 S3 from first time Triumpher mperetz Speed Triple Forum 1 04-12-2007 03:39 PM
Integrated Tail light, brake light and turn signals?? stinger Sprint Forum 15 04-03-2007 10:21 PM
Low-Level Fuel Light--a different issue this time Impatient The Rocket Science Forum 8 07-24-2005 03:11 AM
