Motorcycle.comTrident-Exhausts.comCycleGear.comMotorcycle.com Classifieds!britishcustomsTriumphPerformanceUSABikeBanditSportbikeTrackGearRacerPartsWholesaleShopTriumph.com
CycleGear.com
Old 06-24-2007   #1 (permalink)
I'm thinking of risers for my beloved creamcycle. I don't want the bars raised a lot. At most two inches. Any suggestions?
akenaten is offline   Reply With Quote
Old 06-24-2007   #2 (permalink)
I've been thinking about these from newbonneville.com:
Riser Bars
I think the cables might get fairly tight after pulling them up 1.25" though.
03 T100 Goodwood Green & Aztec Gold with Norman Hyde Togas (Classics)
BillT100 is offline   Reply With Quote
Old 06-25-2007   #3 (permalink)
Stealth's Avatar
Yes, Super big improvement along with being a nice looking product. from N.B. Will work with you current cables. Make sure you slacken the clutch cable before install or you may have the expensive of a new clutch cable.
Stealth
Put your arms and legs inside the ride at all times!
Stealth
125 main /42 pilot /Predators /K&N air/Mobil1 oil & filter
Stealth is offline   Reply With Quote
Old 06-25-2007   #4 (permalink)
webonnielad's Avatar
I got the same risers as those from Jenks.
A friend came over we undid the handle bars to lift 'em up, slid the risers straight underneath onto the top yoke and replaced the clamp.
5 minutes flat, no more back ache. looks cool as hell.
Jon (UK)
webonnielad is offline   Reply With Quote
High Rise Bars on a Bonnie? rmak Twins Technical Talk 25 01-07-2008 04:07 PM
Spectacular Earth rise shots Tbirdnz Biker Hang-Out 9 11-15-2007 02:44 PM
noticeable rise in compression Hammer101 Modifications & Workshop Talk 3 06-08-2006 12:54 AM
Clipons with rise odium Speed Triple Forum 7 06-03-2006 01:56 PM
cant rise cause its snowing solution retro900 Club Cafe 3 01-21-2006 01:41 PM
