One thought, assuming it ran good before, is to get a bottle of "seafoam" and add it to the gas and run a tankful thru. If it a gummed up carb that should clean it out. If it was fine before the sit i would think thats likely what it is. Seafoam is a well regarded product and is available at some auto parts stores here in the U.S. I believe i got it at auto zone, tho not sure where you'd find it in AU.
