In all probability you need... guess what... brake grease.
This stuff does NOT go on the friction surface of the pad that contacts the disc. Rather, it is applied to any of the other surfaces that may contact each other, especially the tin clips that hold tension to the pads.
When you brake, all of these things vibrate and so make noise. The grease quiets this. It is available in tiny packages in any auto parts store. I don't know if you have to completely remove the from the calipers to apply it, but I would think you do. You certainly need to remove the calipers from the bike. If you are not comfortable with this, see a mechanic.
Lets be clear one more time - you never put any substance on the face of the pad or the disc itself.
I suspect your washing removed the little grease that was there.
