RacerPartsWholesaleTrident-Exhausts.comSportbikeTrackGearTriumphPerformanceUSABikeBanditSpringfield ArmorybritishcustomsShopTriumph.comAnnitori DistributingMotorcycle.com Classifieds!
Springfield Armory
Old 06-21-2007   #1 (permalink)
Favorite Bike: 2007 Bonneville Black
TommyTwin's Avatar
I've just had an airbox elimination kit put on my bike...it has TOR's and AI removed. The kit came with 150's but it feels like the bike is getting a little too much gas when I open it up....I'm thinking about dropping down jet size.
Anyone have thoughts on this topic?
TommyTwin is offline   Reply With Quote
Old 06-21-2007   #2 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
150 main jets is what should come with an Airbox elimination kit for a 790cc with more open silencers (865's typically run smaller main jets for similar mods). I believe your '07 is an 865 and with TOR's, I would expect the mains to be somewhere in the range nearer 135's. Some of the guys with 865's and TOR's can tell you what they run, and be a lot more informative than me. :-D
Larry
Larry
RedBird is online now   Reply With Quote
Old 06-21-2007   #3 (permalink)
Sean at Brit customs said around sea-level with the AI removed and Air-box removed with Predators on a 865cc bonnie you should run 140's and 42's
2007 BONNEVILLE BLACK
1971 SHOVELHEAD PROJECT
1971 YAMAHA XS 650
1969 TRIUMPH TR6R HARDTAIL
1964 TRIUMPH TR6 PROJECT
DRTYRAT30 is offline   Reply With Quote
Old 06-22-2007   #4 (permalink)
TommyTwin's Avatar
Thanks to both of you guys for the information. I took it to the shop and I believe they are going to put 135's in it.
Thanks again. I'll post an update when I get her back.
Tom.
Old 06-23-2007   #5 (permalink)
Favorite Bike: MINE OF COURSE!
unitedrocker's Avatar
Other Motorcycle: 2005 KTM 450
Extra Motorcycle: Coletta 6'2" pintail
Jenks has the Thrux set with 40/140's. I have found the pilots way too lean. BC's suggestion of 42/140's are definitley making her run better, but she's still lean even with 3 turns on the mix. Going with 45's next week after the set arrives with about 2 turns on the mix to start. Might throw on the CEK while I'm at it. :-D
Let me tell you who have not done the basic box cut K&N BC's and jetting... the bike rolls so much faster now it's unbelieveable. Makes it feel as if you really did some motorwork to her, but you didn't. All I can say is NNIIIIICCCE.
Never settle for the usual.
'05 865 Thrux-ton - Super-Duper Modified: painted inner tube caps yellow, purple tassels on the bars, and pink neon lighting.
unitedrocker is offline   Reply With Quote
Airbox Elimination Kit 5bassman Twins Technical Talk 18 05-28-2008 10:32 PM
Airbox elimination kit .. Which one ? MoToBrIt Club Cafe 13 05-07-2007 11:30 PM
Airbox elimination preperation. Jedhook28 Twins Technical Talk 8 04-30-2007 01:20 AM
jetting? question main size with predators and airbox elimination? sweatmachine Twins Talk 38 09-14-2006 04:46 PM
Airbox Elimination Kit anybody try it. anglen Twins Technical Talk 11 07-31-2006 07:46 PM
