Old 06-21-2007   #1 (permalink)
R100rsman
Hi Everyone,
My seach for a Bonnie continues. I found an 05 with 3500 miles on it. The owner let me test ride it and I noticed that the front brake pulsated on harder braking (after it warned up). My question is, has anyone experienced any issues with warped rotors? I am a bit concerned about buying a bike that will need $300 worth or rotor work.
Thanks
Old 06-21-2007   #2 (permalink)
It has been an issue, and would have been replaced under warranty had the previous owner chosen to do so.
It will not be that much (300) to fix it and I would not let it deter me from an otherwise nice low mileage bike. Another point to ponder..98% of all used vehicles need SOMETHING many times its the reason for sale, and its why you get it relatively cheep. Thats the way it works
G
I just wanted to ride
Old 06-21-2007   #3 (permalink)
SpeedyPete's Avatar
If its just the rotor (and what else could it be really?) I wouldn't worry.
Put your money down and fire it up!
Putting on the new rotor will just bring you closer - you'll make a fine couple, I can tell.
P
I have heard the song of the Sausage Creature!
SpeedyPete is offline   Reply With Quote
Old 06-21-2007   #4 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
If you replace the rotor and the new one warps in a few thousand miles or less, you have a front hub problem. Triumph had a problem with front hubs from one vendor...apparently only a small percentage of bikes were affected.
Good luck,
Larry
Larry
Old 06-26-2007   #5 (permalink)
I am just about to get my front rotor replaced for the second time as it is warped again. First time at 6000kms and now at 10,000kms.
I mentioned about the possiblity of the hub being defective but as of today the word from Triumph was no such thing about defective hubs so all I'm getting is the rotor replaced.
Any comments or proof of the possible hub problem?
Sprocky is offline   Reply With Quote
Old 06-27-2007   #6 (permalink)
Do an Advanced Search on the Bonnie Owners Forum for Warped Rotor, Hub, etc. Tell the search engine to find ALL the words if there is more than one word in a search. Then try the Vertical Twins Hangout, then the BA/SM forum. Good info within the last two years.
2005 T100
Old 06-27-2007   #7 (permalink)
Favorite Bike: 05 T100
There's at least one guy here in the UK that has had his front wheel replaced by Triumph after repeated disc warping. His dealer eventually measured the hub and it wasn't machined correctly thus causing the disc to warp. Triumph in the UK certainly know of this issue, although it's not that common.
Paul.
Herts. UK
Opal & Tangerine 05 T100 (865cc)
(Previously Ducati Monster S4 and numerous UJMs)
Old 06-29-2007   #8 (permalink)
PfM
Favorite Bike: 1961 Triumph Thunderbird
PfM's Avatar
Other Motorcycle: 1959 Triumph Tiger 110
Extra Motorcycle: 2006 Scrambler
Yep, my dealer just advised that a new hub is on its way from the UK. He took my word that the hub runout is 0.09mm and Triumph took his. Now he has to lace a wheel - a black art that I would have thought would not be required, but a new wheel assembly is $1700, so the go is for him to do the hard work and he is not happy. Obviously a known issue.
I checked with a 3rd party who reckons that a hub should have 0mm runout - it is a machined casting after all.
Cheers.
PfM
PfM is offline   Reply With Quote
Old 06-29-2007   #9 (permalink)
Favorite Bike: Bonneville 750cc T140V
Other Motorcycle: Hinkley fake Bonnie T100
Cheers.
PfM
Tell your 3rd party that there is no such thing as zero. All components and processes have a tolerance.
Cheers.
English_Spanner is offline   Reply With Quote
Old 07-02-2007   #10 (permalink)
PfM
PfM's Avatar
This is true, English_Spanner, but you'd have to agree that 0.09mm is way too much.
Cheers
warped rotor? Hozer Club Cafe 6 12-21-2006 10:22 PM
Any one with a Bonnie Warped front brake rotor? scramblerrider Twins Technical Talk 9 11-03-2006 09:31 PM
scrambler warped front rotor scramblerrider Modifications & Workshop Talk 1 10-29-2006 12:59 PM
Warped Front Rotor Update bonnieowner Twins Talk 13 06-16-2005 09:57 PM
