I just finished fitting the lay-flat bracket on my bike - I like it! A lot! I bought the black one, and with the black gauge faces, it looks much better - seems to blend in with that area of the bike. I did not need to put a hole in the housing for the blinker-etc. lights. I simply extended the slotted wire harness cutout by about 1/8 of an inch. Only two items needed to be done which were not in Seth's instructions [maybe I did not see them or they are no brainers].To get the gauges free of the old bracket, I needed to remove the tach wires and the trip meter reset knob - don't drop that screw!!!. I did but luckily found it.
The bracket gives the bike a lower profile, especially when combined with bar end mirrors. I think it would look best with M or drag bars, but I don't think I'd like that position for all around riding. The readability of the gauges is good as well.
If your aim is to reduce your bike's profile, this is a modification I think you'll like.
[Alas, I am not too good with digital cameras and thoroughly clueless with getting photos in the computer. I will learn this and post some pics.]
[ This message was edited by: davidc on 2007-06-20 21:11 ]
