britishcustomsSportbikeTrackGearSpringfield ArmoryCycleGear.comAnnitori DistributingTriumphPerformanceUSATrident-Exhausts.comBikeBanditMotorcycle.com
Old 06-19-2007   #1 (permalink)
hello,
this just happened to me when i got home from work, a six mile ride. well, i turn off my bike and couple seconds after it's completely off, a deep low puff comes out of the exhaust. kinda like how a car can backfire but not that high sound, a low deep sound.
This has never happened to my bike before and it only has 6xx miles on it. Just wondering if anyone experienced this and if this is normal. also, any ways to prevent this from happening again?
thanks.
kidkazi is offline   Reply With Quote
Old 06-19-2007   #2 (permalink)
Never experienced that before.When I come in from a ride,whether its 6 or 60,my bike just shuts off and goes completely silent.No tinkling or ticking or anything.Not like any car I`ve ever owned. Its been the most eerie sound [or un sound] since the very first day I rode it home. :???:
Old 06-20-2007   #3 (permalink)
No, not normal. Without knowing your state of tune, it's hard to diagnose. Sometimes, if a bike is running rich, it will do that as it burns off excess fuel when you stop; however, popping and even back firing on deceleration is common in a lean condition. What silencers, jets, etc are you running?
2005 T100
Old 06-20-2007   #4 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
I have had mine pop pretty loud a few times when I started it up after sitting a few minutes--engine warm. I have never had what you describe happen. I assume you have the Air Injection (AI) system intact. Did you by chance blip the throttle just before shutting off the engine?
Larry
Larry
RedBird is online now   Reply With Quote
Old 06-20-2007   #5 (permalink)
mecscc's Avatar
ditto on Larry's question. Sounds like you got a little post engine spontaneous ignition. What you describe is not a "back fire." And is actually encouraged by the AI system.
If you blip the throttle and then shut down you will send a lot of unburned mixture into the exhaust which can combust. If not, and it continues to do it, exercize your warranty and have the dealer look at it. Otherwise, forget it- and just shut down at idle from now on.
Monte
Monte
"The Old Ohio Preacher Man"
Old 06-20-2007   #6 (permalink)
GCA
The exact same thing has happened to me a couple of times. (Bone stock bike, by the way)
However, it has only happened when pulling up into my garage. There's a little kinda rounded lip between the garage and driveway- the garage floor is about an inch higher, so when I'm pulling in I usually roll the throttle a touch to get up and in, 'cause at that point I'm travelling slowly enough that it takes some manpower to roll the weight up. I assumed that the low pop was just unignited fuel in the exhaust beacuse I shut her down a second or two too soon... of course, if it happened in a different condition, then I'd probably be asking questions myself.
GCA is offline   Reply With Quote
Old 06-20-2007   #7 (permalink)
my bonne is bone stock. i may have bliped the throttle before shut down. btw, what will happen if i take out the AI, pros and cons?
Old 06-20-2007   #8 (permalink)
Mine's done it a few times. I like it though and try to make it happen!
But I also flick the kill switch while riding along to make it pop and bang for the same reason.
Removing the SAI system will stop your pipes going quite as blue, slightly cooler running and less weight and complexity. The cost is more hydrocarbon and CO exhaust emissions.
Kurtis is offline   Reply With Quote
Old 06-20-2007   #9 (permalink)
GOZO's Avatar
KURTIS ....Remove SAI to reduce weight !!!!!
I don't think any of us road riders are that desperate to loose a few grammes. Might be different if your a racer.
Stick to what the members say, excess fuel, hot pipes will cause it , BUT shouldn't, so if it continues take it back to the dealer.
Good luck.
GOZO is offline   Reply With Quote
Old 06-20-2007   #10 (permalink)
Every last gramme!
I even weighed it all when I took it off! I think it came to about half a kilo with the pipes, spigots and solenoid/reed valve...
Then I added some weight in the form of two screws and a cork and some dum dum for the airbox.
Trident - Bad Back fire problem Poddy Sprint Forum 8 11-28-2007 05:45 AM
Bad Back fire problem Poddy Sprint Forum 16 08-25-2007 05:44 AM
Back Fire??? AcidKat Twins Talk 1 03-11-2006 09:00 PM
Normal engine temp? glw The Rocket Science Forum 3 09-28-2005 10:12 AM
What is a normal engine temp? Sprint Forum 6 05-24-2004 04:28 AM
