britishcustomsBikeBanditTriumphPerformanceUSASportbikeTrackGearMotorcycle.comSpringfield ArmoryAnnitori DistributingCycleGear.comShopTriumph.comAdvanstarMotorcycleShows
Old 06-19-2007   #1 (permalink)
I accidentally left he key in the ignition overnight....Went out to start it this morning and it was dead.....nothing, nada, zip. So, when I get home this afternoon, what's the best way to bring it back to life? Jump it from my truck and then ride it around for 20 minutes or so? Bump start it? ?? ? thanks.
Tenover is offline   Reply With Quote
Old 06-19-2007   #2 (permalink)
Favorite Bike: MINE OF COURSE!
unitedrocker's Avatar
Other Motorcycle: 2005 KTM 450
Extra Motorcycle: Coletta 6'2" pintail
Eh... no.
Unless you want the possibility of ruining your electrics $$$ battery, don't jump it. (I guess you CAN jump it, as stated below, but I've occationally had issues with 12 vs smaller batteries) Buy a cheap trickle charger for 30 bucks and charge the battery. You'll be glad you did. Otherwise, Id say bump it, but I'm unsure how that works with electronic ignitions...
[ This message was edited by: unitedrocker on 2007-06-20 08:33 ]
Never settle for the usual.
'05 865 Thrux-ton - Super-Duper Modified: painted inner tube caps yellow, purple tassels on the bars, and pink neon lighting.
unitedrocker is offline   Reply With Quote
Old 06-19-2007   #3 (permalink)
Retired Legend
sweatmachine's Avatar
you can jump it off your truck, just make sure the truck isn't running.
Old 06-19-2007   #4 (permalink)
Ahhh...I forgot about he trickle charger...I actually have one. 12 volt setting, correct?
Thanks.
[ This message was edited by: Tenover on 2007-06-19 13:54 ]
Old 06-19-2007   #5 (permalink)
Just so you know, you can indeeed jump it, but once you do then your alternator will be left trying to charge a dead battery. It wont like it.
charge tha battery first, in all vehicles except really old ones with a generator
G
I just wanted to ride
Old 06-19-2007   #6 (permalink)
Any idea how long I'll have to leave it charging for?
Old 06-19-2007   #7 (permalink)
BEEN THERE - about a month or two ago - I got a friend to help me push start it ( on pretty flat ground) and then I took an hour ride to charge up the battery- she's been fine since- no problems starting her up at all. Just make sure that the first time you turn it off your at the top of a hill :-D Good luck!
SBBonnie is offline   Reply With Quote
Old 06-19-2007   #8 (permalink)
How'd you jump start it, with the key and ignition on and in 2nd gear?
Old 06-19-2007   #9 (permalink)
No. Same as you would if your battery was charged. Just be careful, and as Sweat said, make sure your truck isn't running. After your bike starts, disconnect jumper cables.
Were you intending to type "Bump Start"??
[ This message was edited by: Jimi_X on 2007-06-19 18:03 ]
Jimi_X is offline   Reply With Quote
Old 06-19-2007   #10 (permalink)
GCA
Is the procedure for bump starting a bike the same as in a car, more or less? I'd assume that you need to be pretty balanced for that first kick when you dump the clutch.
GCA is offline   Reply With Quote
NH Togas-Will they wake the dead? (or almost dead) johnnyb84 Twins Technical Talk 32 01-15-2008 01:37 AM
Dead Bonnie bonnieblackinfl Twins Technical Talk 42 10-30-2007 07:33 PM
Need Help ASAP- Bonnie is Dead.... Drift Twins Technical Talk 19 10-16-2007 08:03 PM
i am not dead also convict Twins Talk 22 08-16-2007 11:47 PM
Dead pineygroveshop Tiger Workshop 16 04-08-2007 05:48 PM
