britishcustomsCycleGear.comSpringfield ArmoryTrident-Exhausts.comAnnitori DistributingMotorcycle.comBikeBanditShopTriumph.comAdvanstarMotorcycleShowsSportbikeTrackGear
CycleGear.com
Old 06-17-2007   #1 (permalink)
i'm not sure if the bafflectomy instructions in wiki is for a 07. I remember seeing cut out views for prior 04 and 05 and after baffles and they were different. I can't find that post anymore. I wanted to debaffle mines today but just wanted to recheck the instructions because i really want to complete it in one shot.
kidkazi is offline   Reply With Quote
Old 06-17-2007   #2 (permalink)
Cant say for sure. I cut the last 2" off & all came out w/ no problem. Not sure about the 07 tho? I would think not too much diference? But then again who knows w/ the newer govt specs? Good luck!! :???:
CAPT D
Old 06-17-2007   #3 (permalink)
Good comment because it seems the 06 and later models are a bit trickier to do
2006 T100 - SOLD
hkt100 is offline   Reply With Quote
Old 06-18-2007   #4 (permalink)
I'm looking at doing it too, but cannot really figure out if i can get away with not cutting the ends off, in my understanding is that lip at the end that causes much of the problem in removing the baffle right?
There's more to life than living.
bricktop is offline   Reply With Quote
Old 06-18-2007   #5 (permalink)
Favorite Bike: My Bonnie
Other Motorcycle: My other Bonnie
Extra Motorcycle: '98 FXD
I've got a debaffled/punched pair off my '06 T-100 if you want em. I used CapD's method but only cut off a half inch...worked just fine.
...Billy
(used a "porta-band" saw...it was really easy)<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font class="pn-sub">Code:</font><HR></TD></TR><TR><TD><FONT class="pn-sub"><PRE> </PRE>
[ This message was edited by: BILLYSIM on 2007-06-18 13:10 ]
Shoot safe, straight and often...
BILLYSIM is offline   Reply With Quote
Old 06-18-2007   #6 (permalink)
Favorite Bike: 2007 Bonneville Black
TommyTwin's Avatar
I did mine ('07) using the instructions out on the wiki......I would not recommend using those for newer bikes.
If I were to do it again....I would just cut the ends off and be done with it. Nearly impossible to drill out with a hole saw.
Ended up with TOR's anyway...so it's a happy ending.
TommyTwin is offline   Reply With Quote
Bafflectomy Kirkus51 Twins Technical Talk 1 08-11-2007 03:06 AM
07 bafflectomy koifarm Twins Technical Talk 9 08-09-2007 02:40 PM
My bafflectomy BILLYSIM Twins Technical Talk 3 03-28-2007 11:53 PM
bafflectomy desertrat Twins Technical Talk 12 03-01-2007 10:51 PM
Re: Bafflectomy doctorjay Modifications & Workshop Talk 1 06-30-2006 03:33 PM
