RacerPartsWholesaleCycleGear.comSportbikeTrackGearTriumphPerformanceUSATrident-Exhausts.comShopTriumph.comAdvanstarMotorcycleShowsMotorcycle.com Classifieds!Annitori Distributing
CycleGear.com
Old 06-15-2007   #1 (permalink)
Will the Thruxton mufflers fit on a Bonneville?
I heard that you are able to get adaptor pipes or something, has anyone done this, if so how does it look and sound?
thanks
Lawrence
04 Bonneville
lsettle is offline   Reply With Quote
Old 06-15-2007   #2 (permalink)
I have Thruxton pipes on my Bonnie and I didn't use adapters. It will take a little bending of the existing header pipes to take out a bit of the bend where the mufflers attach.
Then I had the mufflers and the header pipes welded together. (If/when I replace my pipes, I am going 2 into 1.)
Stock - the pipes are very quiet. I did a baffelectomy and drilled a 1 1/4" hole. Now they sound mean. Some might say that they sound too mean, but I like it. I have heard that this set up is a little louder than Predators.
2005 Bonnie Black
jcline8 is offline   Reply With Quote
Old 06-15-2007   #3 (permalink)
Favorite Bike: 2004 Black & White T100
Other Motorcycle: 1970 Honda Monkey Personally Restored in October 2006
I just mounted Kliff's old bafflectomized set on my T100. A little too loud & raspy for me, so I made a baffle that fit over the 1 1/4" hole. Like the sound now!
They went on pretty nicely, it took a little wiggling down near the joint. What bent for me was the perforated section on the mufflers not the header pipes. Just make sure you have enough lube and that the clamp remains on the muffler side. It was also a little tricky to get them to bolt to the rear peg mounts but very doable.
Now I just need to figure out how to make the kickstand stop extension. Can anyone share what they have done to make one, pictures would be nice too?
The look & sound is truly unique!!! :-D
TRYMPH
...Ride On
______
AI Removed / Fork Gaiters / Uni Filter / Thruxton Needles / Polaris Bellmouth / Super Bars / Puig Flyscreen / Thruxton Cans Bafflectomized / Black BBQ Painted Headers / Corbin Gunfighter Seat
TRYMPH is offline   Reply With Quote
Bonneville vs Thruxton Mufflers unitedrocker Twins Technical Talk 6 05-16-2007 01:09 PM
Thruxton mufflers on a Bonneville-lots of questions Motoleo Twins Technical Talk 14 09-15-2006 09:51 PM
Thruxton Mufflers jkieler Twins Technical Talk 0 09-07-2006 09:27 AM
Any opinions on these "universal fit" mufflers? GParks Twins Talk 10 06-19-2006 12:16 PM
TBS mufflers fit standard Thunderbird? Beemie Hinckley Classic Triples 3 04-11-2004 04:46 PM
