britishcustomsSportbikeTrackGearSpringfield ArmoryCycleGear.comAnnitori DistributingTriumphPerformanceUSATrident-Exhausts.comBikeBanditMotorcycle.com
Old 06-14-2007   #1 (permalink)
stu
Favorite Bike: 1952 Vincent Black Shadow
Other Motorcycle: 2002 Bonny
Extra Motorcycle: 2002 Sprint ST
Put my Norman Hyde bars on tonite after dark, using my benchlight. All went easy, until I wanted to turn the banjo fitting down to relieve stress on the fitting at the new bar angle. Unfortunately there is a little projection from the MC that cleverly prevents you doing this. Not to worry, I got a hacksaw blade since its aluminum and crouching down merrily sawed it off. Then I went to the other side of the bike and found a nice deep cut in the banjo fitting as well. It doesn't leak, and now I'm not sure if I should replace the whole brake line or not. :evil: :evil: :evil: :evil:
Stu
TORs, NARK, thruxton needles, 140mains.40 pilots 2.75 turns out, procom igniter, 17T
stu is offline   Reply With Quote
Old 06-14-2007   #2 (permalink)
Favorite Bike: MINE!!
Other Motorcycle: In my dreams
Extra Motorcycle: that's funny
Ouch, I had the same issue when I put my drag bars on, I just decided to live with the odd angle on the break line and not cut anything. Good luck with that. ">
2007 Bonnie Black
NB Drag Bars, Napoleon Bar-Ends, 19t Front Sproket, Bobbed front and rear fender, Lucas style taillight and bullet signal lights, blacked headers (hey, it's different than from when I got it), Matte Black Side Covers, and fenders, Red seat "embossing", Pazzo Racing Black anodized short levers, BC Predator exhaust, ARK & a rejet, AI removed
OTW: painted tank and headlight bucket w/ screen
Cynr1023 is offline   Reply With Quote
Old 06-15-2007   #3 (permalink)
Favorite Bike: My Bonneville of course
The perils of working on your own bike I guess. If it don't leak why worry right? You will only have to tell your story to the most obvious admirers anyhow.
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline   Reply With Quote
Old 06-15-2007   #4 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
Some have replaced the brake line without a real good reason--sounds like you have a good, deep reason to replace the brake line.
Larry
Larry
RedBird is online now   Reply With Quote
Lightning strikes what?! SLOBonnie Twins Talk 13 09-26-2007 05:34 PM
Prince of Darkness Strikes Again... Joemomma Speed Triple Forum 4 06-20-2007 05:06 PM
The Emporor Strikes Back. welshrob Biker Hang-Out 2 02-24-2007 03:40 PM
20 minutes of stupidity and some brakes Thunder_Forever Twins Talk 5 10-28-2005 12:27 PM
Lucas Strikes Again !!! parisphoto Daytona Deliberations 1 07-27-2004 11:21 PM
