CycleGear.comAdvanstarMotorcycleShowsTrident-Exhausts.comSportbikeTrackGearbritishcustomsBikeBanditMotorcycle.com Classifieds!RacerPartsWholesaleSpringfield Armory
Old 06-14-2007   #1 (permalink)
Favorite Bike: Triumph Thruxville :)
BorgCymru's Avatar
Other Motorcycle: Another Triumph
Extra Motorcycle: TR1 Chop/Bobber
I think the ones on the speedmaster are 12.5 inch, I have a set of brand new 12 inch 'Progressives' I bought for a Sportster (spit) , would that .5 of an inch be much of a problem do you think ?
BorgCymru is offline   Reply With Quote
Old 06-14-2007   #2 (permalink)
Probably would not be a problem. you could lower the fork tubes 1/2 inch also to keep the attitude the same, if you wanted. 1 inch or more difference will start to be a noticeable change, imho
G
I just wanted to ride
Old 06-14-2007   #3 (permalink)
BorgCymru's Avatar
I'll have to see how much clearance there is between the wheel and the rear mudguard, but yer I could lower the forks a bit if I wanted to no probs, although I couldn't see .5 of an inch being a problem on the front
Old 06-15-2007   #4 (permalink)
I wonder how your back is going to hold up.In theory you are also shortening the wheel travel.Let us know how they ride especially on bumpy roads. :wow:
speedblue is offline   Reply With Quote
Old 06-15-2007   #5 (permalink)
BorgCymru's Avatar
well I was hoping better quality shocks would take the bumps better
Old 06-16-2007   #6 (permalink)
I should not be commenting actually I still got the lousy-factory worthless shocks myself.Good luck on the shocks.I am going to try the Hagon ones, one day(SOON I hope). I need another front tire.The Bridgestone BT45 has 10,000 miles and is starting to crack pretty bad.I won't buy another Bridgestone after this.At the time when I bought it I did not have the $$$ for the Metzler front tire.Like I said good luck on the shocks. :-D
Old 06-16-2007   #7 (permalink)
BorgCymru's Avatar
I quite like venom tyres and they do white walls, I need a front but the rear is brand spanking new.
Looking for stock Speedmaster shocks ROBD Twins Technical Talk 7 02-26-2007 12:09 AM
Speedmaster shocks for lowering a bonnie? bonniegreen Twins Technical Talk 9 12-10-2006 06:26 PM
Thrux Rear Shocks vs. Bonnie Rear Shocks faffyface Twins Talk 1 01-24-2006 03:54 PM
Wanted;Speedmaster/America rear shocks agro Twins Talk 6 11-25-2005 03:09 PM
What shocks are available for Speedmaster? dazco Twins Talk 6 09-01-2005 10:38 PM
