» Links |
06-14-2007
Formula Extreme Favorite Bike: 02 Bonneville
Posts: 558 Other Motorcycle: 05 SV650S
I'm going to have Ikon progressive fork springs installed on my 02 Bonnie next week.
I've seen several post stating that the stock spacers needs to be cut down, but haven't been able to see if there's any consesus as for the lenght. Didn't get any info from Newbonneville either.
Did a search , and did find one post suggesting 12mm.
Any other suggestions? (BTW, I weigh #230)
02 Bonneville - Originally green/silver , now going black. Dual headlights/black fly screen. Emgo Shortys, rubber bellmouth, Uni, AI, 120/42, thrux needles, no shims. Thruxton seat and low bars. Ikon 7614 shocks, renntec rack. A Bonnie Cafetourer..
I installed them with no spacer and rode for about 10000 miles ,no problem.I recently had a fork seal go bad (pitted tube) and when my mechanic removed the fork he freaked because there was no spacer.When I showed him the difference in lenght(and heft) between the stock bedspring and the Ikon he still said there should be a small spacer....approx . 1 ". This will give a tiny amount of preload.
I felt no difference what so ever on the road.
Get it on,get it up,keep the beat
and RIDE WITH ZEKE
BIR #132
TonUp Club San Diego
06-14-2007
When you pull the stock springs out lay them and the spacer next to the IKONS. Measure the difference, and then cut the spacers down using a "Tubing" cutter about $20.00 from the local hardware store.
Don't worry about cutting the stock spacers, IF you ever want to go back, they're reasonably priced and can be ordered from BikeBandit or your dealer.
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
06-14-2007
Site Supporter SuperSport Favorite Bike: 2005 Bonneville T100 (B&W) - Chromed like a Harley
I didn't use any spacer since none was needed. Just follow the installation instructions:
7) With the forks in their fully extended position place the new springs into the tubes. for minimum unsprung weight when progressive rate springs are being fitted we recommend fitting the spring so that the closer wound coils are at the top.
8) AT THIS POINT YOU MAY OR MAY NOT NEED TO RE-USE OR INSTALL A SPACER. IF THE NEW SPRINGS ARE ABOVE THE FORK TUBE THEN SPACERS WILL NOT BE NEEDED. ....
Rich
"....by its very nature, a single-tracker is in unstable equilibrium, i.e., it cannot, when stationary, stand up by itself."
06-14-2007
I did as CYNCRZR suggested, but instead of cutting down the stock metal spacer, as per advice I found here, I used a piece of white PVC tubing from a sprinkler system. It was the perfect fit, cut easily with my Dremel, and didn't require me to chop the stock spacers (um, just in case I want to go back to the stock springs...?!). You'll find it al Lowe's or any of those big hardware stores (er, or the equivalent in Norway).
Ogle my bike here.
06-14-2007
250 Grand Prix Favorite Bike: 2006 Scrambler
Hehe, just a note. Despite the fact that the showa spacer used in our forks should be common, it still took a few weeks to receive one from Bike Bandit.
06-14-2007
SuperSport Favorite Bike: 2003 Triumph T100
Posts: 1,086 Other Motorcycle: 2007 M-G Cali Vintage
Like others above, my Ikon springs protruded out the top of the fork tubes. I used no spacer and find that the forks suit me just fine.
06-14-2007
Here is a question...I put in progressive springs and cut the spacers to match the same length as the stock spring/spacer combination.
I am a pretty heavy guy. Will it help if I actually increase the preload by using longer spacers?
2005 Bonnie Black
06-15-2007
I matched the free lengths. Measure the free length of the new spring compared to the old spring and spacer, whatever the difference is, chop it off the spacer.
I used one spacer to make two new ones and had loads spare. The matching of free lengths means that my preload adjusters should have the same range of function, allowing for the reduction in sag.
I used more basic tools to do it, hacksaw and files. Took a while but once deburred they were square and tidy.
The springs and Ikon shocks have much less sag than standard, which will raise the ride height. The major benefits I've seen are increased turn in speed due to the raised C of G, (at the expense of some stability) and increased ground clearance.
06-15-2007
You shouldn't need to add a spacer for the Ikon springs. In fact, adding any spacer/preload to any dual rate spring is counter productive. It changes the spring characteristics as well as altering ride height.
You may as well buy straight rate springs if you are going to preload dula rate springs
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
