Old 06-12-2007   #11 (permalink)
Favorite Bike: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
The issue with ethanol is twofold:
(1) Ethanol absorbs water. This is why it has to be shipped in container trucks rather than run through pipelines. If your fuel tank isn't completely sealed (and of course, they aren't), then the ethanol will slowly absorb water from the air. In the case of our fuel tanks, the exposure is small enough that a 10% ethanol blend will be okay for quite a while - a month or more - but that water is bad for compression in the engine, and can lead to rust in the gas tank.
(2) Ethanol (as is true with about all non-petrol fuels) has a much greater effect on rubber than petrol. Again, at a 10% blend it doesn't seem to cause any trouble, but at higher quantities it will eat any rubber gas lines very quickly. E85 (85% ethanol) eats through hoses so quickly that cars meant to run it have to use steel pipe instead. This is what strikes me as really stupid about the people you see running E85 in their normal cars.
Honestly, I think that Triumph would probably say "No ethanol" just like they say "No methanol" if they could; but in places like Minnesota, all our gas has ethanol in it, so if they hope to sell a bike in those places, they have to allow it.
As with everything, Triumph is playing the odds here. Introducing small amounts of ethanol (or even methanol for that matter) *WILL* raise warranty claims in the aggregate, but only a little - most people will have no trouble. The warranty claims will rise in small enough numbers that it's worth the trade-off for additional sales. So they draw the line at 10%, which hits a sweet spot of increasing sales without inordinately raising warranty claims. They would probably do the same with methanol if it were in wide enough use to raise their sales, but of course it's not, and so there's no incentive for them to risk raising their warranty claims rate.
38% rocker, 30% mod.
lindsayt is offline   Reply With Quote
Old 06-12-2007   #12 (permalink)
Please correct me if I'm wrong, but isn't ambient temp a consideration when choosing the fuel grade? Here in the high California desert, temps often exceen 110*F. I've found that the 91-92 octane fuels perform better in these conditions, but I have no scientific evidence to back that up.
Airboss is offline   Reply With Quote
Old 06-12-2007   #13 (permalink)
HiVel's Avatar
Temperature is indeed a consideration -the hotter it is the more octane your baby needs-I have seen so many blown head gaskets here in cars that supposedly are ok to run regular in the heat of the Alabama summer. I use 93 octane BP/Amoco all the time in all my vehicles (well, about all the time-I used Shell for a while and some Exxon or Sunoco sometimes too!) and have never,( since 1959-Amoco white gas!), had a fuel issue in anything I rode or drove. Even better,if you let the bike sit up there is nothing to settle out and crud up your carbs or injectors --good juice. It may cost you a $100.00 a year to use the 93 -do it! It is worth it despite what the cheap pundits say. They do run better and if you want ahot tip try some TK-7 additive.
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 06-12-2007   #14 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
Try and get yourself some airplane fuel...( about 110 octane here in the states )....I ran some of this stuff in my old BSA Rocket3 and it made the bike run like a scalded dog...
Hated By All....cause thats just how it is.
SCCTrim is offline   Reply With Quote
Performance Mods BonnieRob Twins Technical Talk 3 07-20-2007 07:18 PM
Stainless valves & Unleaded Fuels???? valiantbultaco Classic, Vintage & Veteran 9 02-27-2007 06:15 PM
Performance JRO Tiger Chat 6 02-07-2006 06:55 PM
performance #'s Sheepdog Twins Talk 2 12-06-2005 03:13 PM
Performance coastie Club Cafe 26 07-24-2005 12:13 PM
