Trident-Exhausts.comSpringfield ArmoryShopTriumph.comSportbikeTrackGearCycleGear.comMotorcycle.comMotorcycle.com Classifieds!britishcustomsRacerPartsWholesale
Old 06-11-2007   #1 (permalink)
dat
I high sided the bonnie and have bent the gear shift shaft.
Has anyone removed the gear shifter shaft on a 865 bonnie? I have removed the engine casing and circlips on the shaft but the shaft still wont come out. Does anyone know how to get it out? Also if someone has replaced one how much?
Old 06-11-2007   #2 (permalink)
dat
ANYONE????
Old 06-11-2007   #3 (permalink)
I haven't pulled it out but I did have a look in the manual.
It looks like it has to come out from the right hand side after the counter shaft sprocket and gearchange mechanism cover have come off.
If you have tried this and it still won't come out then I would suggest that it being bent is keeping it in place. You will have to cut it off or straighten it some how.
Good Luck
Do you have the Triumph workshop manual?
[ This message was edited by: DickBender on 2007-06-11 16:49 ]
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline   Reply With Quote
Old 06-11-2007   #4 (permalink)
I haven't pulled the shaft yet, but I did have to reset both circlips after my son dumped Bonnie on the shifter in the driveway. If you don't have a shop manual try this bikebandit link to see an exploded diagram of the shifting mechanism.
http://houseofmotorcycles.bikebandit...E+%26+T100.asp
I'd get a copy of a good maintenance manual before I started cutting on any part of the shifting mechanism.
Good luck
PUKKA is offline   Reply With Quote
Gear shifter????? Stampy Speed Triple Forum 0 01-03-2008 03:46 PM
Need tech. info: shifter shaft replacement, priming oil system eighty6gt Speed Triple Forum 5 12-01-2007 03:36 PM
Broken shifter shaft ClassiclyMobile Hinckley Classic Triples 35 06-21-2007 09:17 PM
Shifter shaft seal smartin108 Tiger Workshop 2 01-21-2006 10:15 AM
gear shifter on TBS Hinckley Classic Triples 9 08-29-2004 11:57 PM
