britishcustomsSportbikeTrackGearSpringfield ArmoryCycleGear.comAnnitori DistributingTriumphPerformanceUSATrident-Exhausts.comBikeBanditMotorcycle.com
Old 06-11-2007   #1 (permalink)
PfM
Favorite Bike: 1961 Triumph Thunderbird
PfM's Avatar
Other Motorcycle: 1959 Triumph Tiger 110
Extra Motorcycle: 2006 Scrambler
Had my front disk on the Scrambler replaced about 3 weeks ago. Now it feels warped again., so I ran a dial gauge over it and getting about 0.3mm runout - which is the service limit. Then tried the dial gauge over the outside face of the hub, just inside where the disk mounts. This is showing 0.08mm runout.
Questions:
Anybody else been in this situation where discs keep warping and the hub is found to be at issue?
Anybody know what the specified runout for the hub is ? It is not in the factory manual.
Cheers
PfM
PfM is offline   Reply With Quote
Old 06-11-2007   #2 (permalink)
Leeroy's Avatar
If you use the front brake hard (I do), there can a be problems with disk warping. I decided after only 500 miles to change my front rotor and pads. EBC makes a nice replacement for the stock ones. The rotor is a full floater and greatly helps with disk warping problems.
Rotor- EBC MD649LS
Pads- EBC FA196HH
Check for the wheel being true also. Spokes might need tweaking a bit. I doubt the hub is warped.
Leeroy is offline   Reply With Quote
Old 06-11-2007   #3 (permalink)
Here's my experience, PfM:
WARPED ROTOR
Bob
bobmig is online now   Reply With Quote
Old 06-11-2007   #4 (permalink)
Yes there is experience with this. Repeated warped discs are indicative of a hub problem requiring replacement.
2005 T100
Front Disk movement DaveLee808 Sprint Forum 8 08-02-2007 08:46 AM
Disk Brake question 666Bonneville Classic, Vintage & Veteran 11 06-08-2007 04:33 PM
New brake disk - Again! Lobo Twins Technical Talk 9 09-19-2006 09:59 AM
Front disk vibration c_marcus3 Speed Triple Forum 6 02-26-2006 01:00 AM
new front disk & old brakes adamh Twins Talk 24 11-28-2005 01:23 PM
