britishcustomsBikeBanditTriumphPerformanceUSASportbikeTrackGearMotorcycle.comSpringfield ArmoryAnnitori DistributingCycleGear.comShopTriumph.comAdvanstarMotorcycleShows
Old 06-10-2007   #1 (permalink)
I want to remove the reflectors that are glued onto the sides of the rear fender. Don't want to cause any damage. Any suggestions from those that have done it?
Thanks
Adam
Alyron619 is offline   Reply With Quote
Old 06-10-2007   #2 (permalink)
REVOLT's Avatar
fishing line...wrap the ends around your index fingers...use a sawing motion back and forth...that will cut the foam...then grab a can of WD40 or some starter fluid...soak the adhesive that sticks to the fender....and gradually work it off with your thumbnail....wax the area when your done. No harm, No sign they were even there...
The Bonnie Situation...
REVOLT is offline   Reply With Quote
Old 06-10-2007   #3 (permalink)
Favorite Bike: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
On other vehicles, I've done it with fishing line to remove the reflectors, then Goo-Gone to get rid of the remaining foam and adhesive. It's some great stuff, and should cause no problem for your paint as long as you rinse it off when you're done. And of course, apply wax, as mentioned above.
2005 Aegean Blue Bonneville - stock, Ikon front fork springs
lindsayt is offline   Reply With Quote
Old 06-10-2007   #4 (permalink)
Get some dental floss. Cut off a couple of feet or less. Use this as a "knife" to remove the reflector. Try to cut through the adhesive with the floss closer to the reflector than the paint. This will cut the reflector right off, leaving you to clean off the goo. I used WD40, my fingernail, and a lot of patience, but I had no damage to the paint. Don't use a strong solvent--WD40 or kerosene are as strong as I would go.
2005 T100
Old 06-10-2007   #5 (permalink)
TCL
Favorite Bike: Triumph Bonneville T-100
TCL's Avatar
Other Motorcycle: 1977 Honda CB400F
Also helps to heat it up a bit with a heat gun or just leave it in the sun a bit before attempting to remove it.
Death or Glory
TCL is offline   Reply With Quote
Old 06-10-2007   #6 (permalink)
Favorite Bike: 2006 Thruxton "Zoe"
mr_badda_bing's Avatar
I did it the same way, with a hair drier. Then I used some WD40 to remove the adhesive that was left on. Then I used some sand paper to rought it up a bit. Then I painted the fender black.
2006 Thruxton - Zoe Yellowbike
125 main jets, 42 pilots, 1 shims, 2 turns, HARK (homemade airbox removal kit) EMGO Reverse Cones, 17T sprocket. 4700 Feet Above Sea Level
mr_badda_bing is offline   Reply With Quote
Old 06-10-2007   #7 (permalink)
I did no painting - heated them and used Goop for the adhesive, the some wax. By the way, I removed the front ones the same way and then realized how dopey it looked with the bare bracket sitting there and took the bracket off. Should have done that in the first place. :???:
davidc is offline   Reply With Quote
Old 06-10-2007   #8 (permalink)
Thanks for the advice. It's a minor project for tomorrow, the start of a two week vacation.
Adam
Reflectors??? On or off........ AceT100 Twins Technical Talk 40 08-14-2007 11:24 PM
removing rear fender reflectors Freeze Twins Talk 17 06-08-2006 11:37 PM
removing reflectors ocman Twins Talk 9 04-11-2006 08:49 AM
removing unsightly rear reflectors on '02-'04? fwhite Speed Triple Forum 7 05-29-2005 09:37 PM
Reflectors joeygloor Speed Triple Forum 9 08-12-2004 05:01 PM
