» Links |
06-08-2007
Formula Extreme Favorite Bike: 1952 Vincent Black Shadow
Posts: 463 Other Motorcycle: 2002 Bonny Extra Motorcycle: 2002 Sprint ST
I have always run regular gas in my 02 because the previous owner did. I only noticed today the handbook calls for 89 min. Is there a knock sensor that retards the ignition on the lower grade gas?
Stu
TORs, NARK, thruxton needles, 140mains.40 pilots 2.75 turns out, procom igniter, 17T
Yes, there are knock sensors. They hang off either side of your head and they are know to laypersons as ears.
If you haven't noticed any knocking chances are the gas you are using is fine. This doesn't mean that the gas will remain fine, like on a really hot day in heavy traffic and under heavy load. Just keep listening and adjust as necessary.
[ This message was edited by: Jimbonnie on 2007-06-08 14:05 ]
06-08-2007
Filled mine one day w/ regular by habit (car). It didnt feel any different? I am sure over time it woulldnt do the engine any good? Kinda ironic that was the day I had the tank geyser ! Maybe thats why it didnt explode - crappy gas? It made a huge vapor cloud on that hot engine ! :???:
CAPT D
06-08-2007
CAPT D
06-08-2007
Site Supporter Retired Legend Favorite Bike: 904cc Bonnie w/magwheels
capt don, "crappy gas" as you call it will ignite easier than premium grade gas. Higher octane = more resistance to premature ignition (aka knock). I doubt there's enough of a difference to make the gas ignite or not ignite on a hot engine, but low octane fuel would be the easier to ignite.
06-08-2007
250 Grand Prix Favorite Bike: 2006 Scrambler
Hehe, no. The electronic ignition on this bike isn't quite that advanced.
In laymans terms, octane represents the resistance to pre-detonation due to pressure or heat. The higher the octane rating the higher the resistance. If the engine isn't pinging (pre-detonating) then there isn't any issue with using lower octane fuel.
I'm surprised 89 is even suggested. Is that american or european rating? (average or RON rating). The american rating is a couple of points below the european. The engine is such low compression that it can probably run safely on some pretty cruddy gas.
06-08-2007
Speaking of gas, I always buy premium for my bikes, a habit from feeding the old british iron in the stable, but I was told to use the 87 with my new bonnie.
What's the recommendation?
-Ben
http://www.bendavanza.com
06-08-2007
The manual says octane of 95 RON minimum. Is RON the same octane rating used in the USA?
-Ben
06-08-2007
World SuperBike Favorite Bike: 2005 Bonneville T-100
-Ben
No, or we would be running Jojie style drag bikes.... :-D
06-08-2007
(RON+MON)/2=US rate at pumps
89 is the book recomendation for the US
