For a long time I was running stock jetting with the Staintunes and no airbox/filter mod. For the most part, despite definitely being on the lean side, the bike ran fine. I was getting all sorts of fantastic popping on decel too. Some don't like that but I loved it. Only problem with this set up was difficulty getting the bike started in the morning when is was below 40 deg out. You'd probably benefit by going to 42 pilots and maybe 115 mains, but don't feel that you have to. She'll run fine with the stock jetting until you decide on what to do with the airbox.
I've since gutted the airbox and installed K&N's. When I did that I went to 42 pilots and 130 mains. I definitely got a little more "oomph" by doing this and she's running better than ever. Cold starts are not a problem now but I think I'm still a little on the lean side under throttle and will probably end up going up another size or two on the mains.
2003 790 (black, not Black) KARK'd, K&N Cones, Staintunes, 130/42 jets, 2.5 turns out, BC Superbars, CRG LS mirrors, Generic Rubber, 16t
God I love coffee.
