Okay, perhaps it is Dain Brammage from rebreathing the air (on a submarine), but I found the Tachometer works alot beter if you fully insert the new wire into the harness. I needed to use the wire from between the ignitor and the wiring harness despite what the instructions say about the VIN numbers though.
Jesus Hoffa
"It is better to be hated for what you are, than to be loved for something you are not"
