BikeBanditTrident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShows
Old 06-05-2007   #1 (permalink)
Favorite Bike: My Bonnie
Other Motorcycle: My other Bonnie
Extra Motorcycle: '98 FXD
I was thinking of mounting some daytime running bullet lights...can anyone advise if the marker/position light wires will handle 10 amps or so? Is taking the #10 , 5amp fuse up to a 10 amp just too risky?
...Billy
Shoot safe, straight and often...
BILLYSIM is offline   Reply With Quote
Old 06-05-2007   #2 (permalink)
Do I have to run extra wires and install a relay?
Old 06-05-2007   #3 (permalink)
cw
Favorite Bike: 2006 Scrambler
The front indicators are switched and have a blinker relay attached to them. It is probably not a good idea to power running lights through the indicator circuit.
Find out the maximum wattage of your running lights. Given the amp values you provided here are the conversion to power:
5amp * 12volt = 60watts
10amp * 12volt = 120watts
Do the running lights combined with whatever load is on the circuit fit well within those values?
A second idea would be to buy some dual filament turn signals. One filament is always on and the other is the 'blinker'. This is how the brake light works. You'd have to wire the always on filament to the ignition or a switched power lead.
A third idea would be to wire the indicators so they are on when not in use and flash when in use (versus off when not in use).
cw is offline   Reply With Quote
Old 06-05-2007   #4 (permalink)
I'm talking about the marker/indicator (Haynes speak) in the headlight, not the turn signals...
...Billy
Old 06-05-2007   #5 (permalink)
cw
...Billy
Ah, you mean the thing that drains your battery when you turn the key the wrong way.
Is that bulb on when the bike is running?
Old 06-05-2007   #6 (permalink)
I spliced a wire into the "parking" light (little bulb inside the headlight shell) to power my dual filament turn signals to make them "running" lights as well as turn signals. I don't remember schit about electricity from school, so I don't know if that is safe. All I know is several thousand miles and rainstorms later, no blown fuses or melted wiring. Don't ask me what wattage the bulbs are in the dual filament turn signals. Just your average OTC aftermarket dual filament turn signals.
"Well, everybody likes motorcycles... to some degree."
- Bob Dylan
'05 Thruxton, Epco, RaceTech fork springs & cartridge emulators, YSS Shocks, Unifilter, snorkel out, 130 mains, 40 pilot, 1 shim, pilot screw 3 turns, turtle wax
05Truxter is offline   Reply With Quote
Old 06-06-2007   #7 (permalink)
Thrux,
Should be about 5 watts apiece (like the tail light)....so at least the little parking bulb hookup is good for 10 watts. Thanks for the feedback.
cw,
Yes, mine is on all the time, right along w/ the headlight.
[ This message was edited by: BILLYSIM on 2007-06-06 05:25 ]
Old 06-06-2007   #8 (permalink)
I'm using the parking light circuit to run LED clusters in Kurlyn (sp?) Silver Bullets which I mounted with NewBonneville.com's signal relocation bracket (mounts with the rectifie/regulator bolts) Nice combo, easy install. I don't use the park lite bulb anyway since I installed a sealed beam headlight. The original Kurlyn lights were much too bright to be left on at night so I got direct replacment base LED clusters. I didn't run the Kurlyn bulbs off that circuit thought, really felt the draw would be too high.
some pics here:
http://s196.photobucket.com/albums/a...nnie%20Lights/
[ This message was edited by: merlin on 2007-06-06 22:15 ]
merlin is offline   Reply With Quote
Old 06-07-2007   #9 (permalink)
Thanks merlin!
Nice pics...just what I was thinking but I forgot all about using LED clusters. Brilliant!
Low wattage, last forever, safety markers...just what I wanted. :razz:
Looks great too.
Old 06-07-2007   #10 (permalink)
Anytime...
Marker lights VrnJames Twins Technical Talk 12 05-06-2007 09:57 PM
Bullet Marker Lights Install - How to? Tenover Twins Technical Talk 5 06-27-2006 04:35 PM
New Bonneville Bullet Marker Lights Tenover Twins Technical Talk 5 06-26-2006 10:40 PM
Tail Light Wires GrahamC Speed Triple Forum 0 06-21-2006 05:16 PM
Turn Signals vs. Marker Lights Mancha Twins Talk 7 03-13-2006 10:01 AM
