britishcustomsCycleGear.comSpringfield ArmoryTrident-Exhausts.comAnnitori DistributingMotorcycle.comBikeBanditShopTriumph.comAdvanstarMotorcycleShowsSportbikeTrackGear
CycleGear.com
Old 06-02-2007   #1 (permalink)
jimmything's Avatar
Just ordered a uni-filter for my speedy. It'll be interesting to see if I can tell any performance increase. At least you can clean and reuse it too. A riding bud told me that he cleans his in dish detergent with hot water, and thens sprays it with marvel mystery oil. I might try it when it needs it. :-D
2006 black Speedmaster with Epco pipes, 130 mains, snorkel and AI removed, UNI filter, drilled airbox, Corbin solo seat.
"Ride it like you stole it"
jimmything is offline   Reply With Quote
Old 06-02-2007   #2 (permalink)
I use dishwashing liquid too. It's made to dissolve grease so it's perfect. I could tell the difference, but it's totally dependant on the bike's state of tune. Giving it more air isn't necessarily going to make it run stronger. It could actually do the opposite........as i said depending on the bike's state of tune, or what it NEEDS. If it's running on the rich side you may well feel and improvement because the extra air will lean it a bit and get the mixture closer to optimum. Of if it's not needing more air, you may get the extra oomph by rejetting richer so it then CAN use the extra air to balance out the extra fuel, IE: better balanced and MORE mixture.
In other words, the UNI does flow more air than stock, and if the bike is in a state of tune where that would be beneficial, or you make it so, then the difference should be felt. I felt a difference with mine. But heres the deal.......the good thing about them is as you mentioned the ability to clean them. Not just because you don't have to buy new filters when they get dirty. But because as a stock filter ages it's constantly degrading from day one in it's ability to flow. So you have les and les air flow every day from the day the filter is new to when it's ready for the trash heap. To keep it like new so your performance never drops off you'd have to replace the $25 filter every couple months or whatever. With the UNI you can clean it on a regular basis so that you always have peace of mind that your bike is running it's best, at least as far as mixture. I think they're a must in my book. K&N's are supposed to be good too, tho i have no experience with them.
Old 06-02-2007   #3 (permalink)
jimmything's Avatar
You're correct about how the uni can lean out the mixture due to increased air flow. I'm fortunate that mine is running slightly rich, so the uni filter should even it out just right. And like you mentioned, a paper air filter starts clogging up from day one. You can clean the uni as often as you like...I think the K&N's cost a bit more too. The uni is just as good. :-D
Old 06-04-2007   #4 (permalink)
Willyrover's Avatar
Do you guys have a part number for the uni filter. Im in Aus and my local dealer has K&N but I would like to try the UNI.
Thanks a bunch
2008 Speedmaster (Black)
Willyrover is offline   Reply With Quote
Old 06-04-2007   #5 (permalink)
Favorite Bike: 2003 speedmaster
pratt's Avatar
here ya go....UNI filters for Triumph
pratt is offline   Reply With Quote
Old 06-07-2007   #6 (permalink)
Favorite Bike: 1966 Bonnie
amanger's Avatar
Thanks a bunch
Unifilter have a office in Sydney.Look them up in the yellow pages.I did a airbox removale and put unifilter pods on my Bonnie for under AU$65.
07 865 Silver Bonnie....Bobbed Guards, Tacho, Grab Rail, Lucas Tail light, Mini Blinkers, Dart Screen, LSL Sport Bars, 1" Longer Hagons, 10mm Raised Forks, K&N Pods, Staintunes, 140/40 3 1/2 turns + 1 shim......etc....etc...
Old 06-08-2007   #7 (permalink)
Willyrover's Avatar
Ok I tracked down UNI Filter, they are out near Hornsby. I have just ordered it and the part number is NU-3702. This is for a 2001 to 2005 America but im sure it is the same as my 2007 Speedy.
Derek
Old 06-09-2007   #8 (permalink)
Derek
Buy the Aussie made one much cheaper!!http://www.uniflow.com.au/
"Whale Oil Beef Hooked"
agro is offline   Reply With Quote
Old 06-10-2007   #9 (permalink)
Derek
No really......UNI from Brent, $28.95. $39 Aus dollar converted to US dollar=$32. So the UNI is actually cheaper By about $3.
Old 06-10-2007   #10 (permalink)
Willyrover's Avatar
when you click the uniflow link that was provided above, it takes you to the Uni Filter site where I ordered my filter from.
Uni flow, uni filter same thing
Derek
Uni Filter vs NARK? Kramocker Twins Technical Talk 7 09-24-2007 04:36 PM
Is this a K&N or Uni filter Skyblue62 Twins Technical Talk 8 09-01-2007 06:52 PM
Cleaning the UNI Filter webonnielad Twins Technical Talk 3 08-07-2007 11:20 PM
Uni Air Filter itcha Twins Technical Talk 0 03-07-2007 06:16 PM
Uni-filter gm16sw Twins Technical Talk 3 07-10-2006 09:18 PM
