Motorcycle.combritishcustomsCycleGear.comTrident-Exhausts.comSportbikeTrackGearSpringfield ArmoryTriumphPerformanceUSAMotorcycle.com Classifieds!AdvanstarMotorcycleShowsAnnitori Distributing
CycleGear.com
Old 06-05-2007   #21 (permalink)
On 2007-06-05 00:47, HarveyMushman wrote:
So can you use tubeless tires on the scrambler rims, or do you have to run tubes regardless?
You have to run tubes, unless you figure out a sure way to seal the spoke holes in the rim. Maybe Rodburner could weld a steel strip around the interior of the rim, but bear in mind, reducing the "drop center" depth of the rim will make it tougher to change tires.
[ This message was edited by: Kevin57 on 2007-06-05 06:17 ]
2007 Goodwood Bonnie, AI removed, evap canisters removed, bafflectomy, fork gaitors, M bars, 19T sprocket, America drivers pegs (no offset), knee pads, checkerboard tank stripe, gold seat logo, rear signal relo, silver cam cover, "8-ball" choke pull.
Kevin57 is offline   Reply With Quote
Old 06-05-2007   #22 (permalink)
The michelin's and I believe the metzler's as well are rated by the manufacturer to run with or without tubes.
tsholin is offline   Reply With Quote
Old 06-06-2007   #23 (permalink)
Favorite Bike: '06 Triumph Scrambler
Other Motorcycle: '96 Triumph Trophy
Extra Motorcycle: '72 Honda CB350F
I went with Anakees on my Scrambler. Amazing difference.
I was never confident in tight corners with the stock knobblies, but with the Anakees, it loves to lean over.
I considered the Tourances as well, just decided I liked the look of the Anakees a bit more.
There is a place here in So Cal called Wheel Works that can seal the rims to allow use of tubeless tires. Here is a linky for a magazine article about it. Costs about $60/rim. I've been thinking about getting it done.
--Josh
59 Club member #029466
'06 Scram. TORs, UNI filter, 120 mains, 1 shim. Ikon 7614 shocks, Progressive fork springs, EBC HH brakes, NB Scrambler SuperBars, PIAA Ion Crystal amber headlight, ...
JBarn3 is offline   Reply With Quote
Stock scrambler tires have to go Varna2Win Twins Technical Talk 20 01-15-2008 11:33 AM
New Tires -- Scrambler McQueen278 Twins Technical Talk 11 03-30-2007 06:14 AM
Scrambler tires? scramblerrider Twins Technical Talk 1 10-11-2006 12:56 AM
Scrambler Replacement Tires TomS Twins Technical Talk 3 08-03-2006 10:06 AM
Scrambler Tires Badhorse Twins Talk 3 04-25-2006 11:17 AM
