If you removed the AI, and it still does it, my guess (since you havent touched the mixture) is that it is lean.
You could install the thrux needle and / or adjust the idle mixture a tad richer. I have had good luck with jenks tuning guide, he says 790 stock needle, your jetting is good, but needs 1 or 2 shims on the needle and 2.5 turns out on the pilot screw.
If you put the thrux needle in, go 135 mains, 1 shim and 3 turns out on the screws. good luck
G
[ This message was edited by: Geoff on 2007-06-01 06:09 ]
