» Links |
06-01-2007
BACKGROUND:
04 Black, baffelectomy, uni filter, thruxton needle with 1 shim, snorkel removed, 125 mains, 40 pilots, 2.5 turns out.
Bike was running strong. Plugs looked good, no popping etc. Pinched neutral wire putting sprocket cover back on, fixed with tape.
Bike starts easily, revs in neutral OK.
Bike keeps running poorly, low power, hesitation, surge under 3500 rpm, runs strong when accelerating after 3500 rpm. Can't figure it out. Any help appreciated. Thanks
You've never rode until you've been throwed.
Site Supporter Retired Legend Favorite Bike: 904cc Bonnie w/magwheels
maybe try taking that shim off...
06-01-2007
World SuperBike Favorite Bike: 2005 Bonneville T-100
How does the idle sound?
06-01-2007
SuperStock Favorite Bike: '06 T100
I'm just theorizing here, but with the setup you describe, your bike seems to be inhaling a lot freer than it's exhaling. (just a baffelectomy).
Also, I think your jet size would be alright with the stock needle, but perhaps too large for the thruxton needle and your setup.
The first and simplest thing I'd try would be go back to the stock needle and leave everything else the same. Next, try without the shim.
Some people are a lot like Slinkys.
Not really good for anything, but bring a smile to your face when you push them down the stairs.
06-01-2007
250 Grand Prix Favorite Bike: 2006 Triumph T100
Posts: 120 Other Motorcycle: 1968 Triumph Bonneville Extra Motorcycle: 1972 Suzuki T500
Yep I think Big Rick is on to it seem way to rich for just minor exhaust mod.
Triumph supply a 115 jet up from a 110 with TORS for a 865
John
New Plymouth
New Zealand
06-01-2007
So what you're say'n is your bike started running bad right after you pinched the neutral wire?
the neutral wire has nothing to do with it. His jetting is off. Thrux needles are a lot richer than 790 needles, plus he added a shim.
I say keep the jetting, get new exhaust!
06-01-2007
Thanks for the input. The bike has been pulling just fine for the last two months. It is a very complete baffelectomy. Jetting seemed fine and I have been through jets from 112.5 to 128 and ended up with 125s. This just started happening, virtually overnight . I'm wondering if it might be a coil issue or maybe clogged pilot jets. I have 1 month under warranty and may try and get it in if I can't find anything.
[ This message was edited by: Anchorbend on 2007-05-31 23:39 ]
06-01-2007
Yes, they did have side stand switches. By pinching the neutral wire it disabled the switch and the neutral light was always on. The bike ran fine despite the wire being pinched and shorting out on the case.
06-01-2007
to diagnose if the neutral wire is the culprit, you can simply remove it from the case (near the oil filter) and disconnect it behind the side cover. The bike will think it's always in gear, the only problem will be that the bike won't run with the kickstand down, and you'll have to pull in the clutch to start it, but like I said before, the neutral wire is not the problem.
06-01-2007
Problem resolved  . How? Darned if I know. I took the carbs apart, tightened the jets, checked the needles to make sure they were sliding OK, tightened electrical connections, twisted spark plug leads and coil leads, tapped the igniter, tapped the coil, tightened the intake manifolds, prayed to St.Lucas etc.. It is running great again. Took it out for a hard 40mi. run and still OK. In two weeks I will get a 12K valve adjustment, get the carbs in sync and a dyno to see how close I am. I will then have my wife hide my toolbox  .
Thanks to everybody for their input.
