When I brought my used 04 home the first thing I did was change the oil to the manual proscribed 10W40 (Amsoil). After 250 miles I changed again to 20W50 (Amsoil) and that satisfied me and the engine and clutch behaved properly. That was a pricey lesson. Also, I found after a thorough draining the engine capacity was 4 quarts to the top line in the sight window. No apparent oil use in the past 1200 miles. I think you may have been under filled with oil one grade too light.
2001 Bonneville
2004 Bonneville America
