Old 05-30-2007   #1 (permalink)
REVOLT's Avatar
Check it out...I'm cleaning the bike down this afternoon and noticed that the Oil Line (steel braided) on the left side is very close to the header?? I'm wondering if it is too close? So...without riding down to the local dealer to compare the Bonnies on the floor...I was wondering if any of you could take a peak at your Bonnie and let me know how close your oil line is. If it's too close then I'd like to adjust it...maybe I'[ll just do that>? What do you think? Anything to look out for while adjusting it? Now that I think of it, maybe I could fab a heat shield for it?
Thanks a TON in advance...
Here is mine...it's ***** near touching the header?
The Bonnie Situation...
REVOLT is offline   Reply With Quote
Old 05-30-2007   #2 (permalink)
I'd be more concerned with the fact that it moved at all...
merlin is offline   Reply With Quote
Old 05-30-2007   #3 (permalink)
REVOLT's Avatar
I checked for "play" and it's on there, it's not moving a bit...I also went through some pictures I have of that area...and it seems it has been like that since day one.
Old 05-30-2007   #4 (permalink)
Picture real dark. I cant tell if the angle or what? I was gonna compare w/ mine. Its close but cant tell how close on your pic? :???:
CAPT D
Old 05-30-2007   #5 (permalink)
Favorite Bike: 05 Black Speedmaster
It looks a bit close, I would loosen the fastener just slightly and pry it over.
Old 05-30-2007   #6 (permalink)
Sloppy assembly, IMHO. Mine is a little closer to the header than to the frame tube, and I would assemble it closer to the frame tube. However, mine is not close enough to bother with moving, IMHO. By the way, I would call that the right side of the engine rather than the left side. :-D
Larry
Larry
Old 05-30-2007   #7 (permalink)
Mine is at least a quarter inch away. Probably does not matter, but now that you see it, it'll bother the hell out of you until its moved. Give in and find peace of mind!
davidc is offline   Reply With Quote
Old 05-30-2007   #8 (permalink)
Favorite Bike: Was 2006 Black Bonneville
oldmanjob's Avatar
Mine is also a quarter of an inch away :wow:
John 14:6 KJV
Black Bonnie - 06
Looking back to the good old days is not the way out. Looking up to the God of All the Days is. (Vance Havner)
oldmanjob is offline   Reply With Quote
Old 05-30-2007   #9 (permalink)
Mine looks like a bit more than 1/4" away, enough to be safe. Now that you've given me something to worry about, I might move it over a bit.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
Baltobonneville is online now   Reply With Quote
Old 05-30-2007   #10 (permalink)
bonnevillebilly's Avatar
you made me go out to the garage and look.
Mine is a good 5/8" away from the header pipe.
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
Oil leak from oil cooler pipe? FlyBri Twins Technical Talk 3 06-21-2007 11:58 AM
07 oil cooler... trumppa Speed Triple Forum 9 03-05-2007 02:33 PM
oil grunge on oil cooler cable lines? tekmoe Speed Triple Forum 1 05-19-2006 01:29 PM
Oil Cooler Bushwhacker Hinckley Classic Triples 0 04-12-2005 07:39 PM
