Motorcycle.combritishcustomsCycleGear.comTrident-Exhausts.comSportbikeTrackGearSpringfield ArmoryTriumphPerformanceUSAMotorcycle.com Classifieds!AdvanstarMotorcycleShowsAnnitori Distributing
CycleGear.com
Old 05-30-2007   #1 (permalink)
Hi guys, new to this forum and to Bonnys, I have a problem with the clutch hoping someone can help. I removed the clutch side cover to get it repolished, after putting it all back together, the clutch was real soft, then I noticed the pin that connects to the spring kept rising when the lever was pulled, now the pin has come out and I got no clutch, any idea on what i missed or is missing.
Cheers
Darren
Bugsy-12GSRC is offline   Reply With Quote
Old 05-30-2007   #2 (permalink)
I can't even tell which end you're talking about ... start here:
http://www.bikebandit.com/partsbandi...ept_id=2291044
merlin is offline   Reply With Quote
Old 05-30-2007   #3 (permalink)
Remove the cover again, then find the push rod since it sounds like it has dropped out of it's hole. And then put it back together making sure there is a little spring at the end (bottom) of that part you see moving up and down now, and that that spring is in tension and holds the push rod in place (you will know what I'm talking about once you have a look in there) And don't move the actuator arm untill the cover is bolted up or the push rod will drop out again.
jojje1963 is offline   Reply With Quote
Old 05-30-2007   #4 (permalink)
Thanks guys, will remove the cover and start over. Appreciate the help.
Cheers
Darren
Old 05-31-2007   #5 (permalink)
Hi Jojje
I took the cover off, did as you said, had tension there as i put it back together and connected the clutch cable, but as soon as you pull the clutch lever in the push rod jumps up out of the spring.
Old 05-31-2007   #6 (permalink)
Found the problem, the bullit shaped pin had come out, just got to find out if it matters if the flat end goes into the cover or the rounded end.
Cheers
Darren
Old 05-31-2007   #7 (permalink)
Cheers
Darren
Yes, that's the pushrod I was talking about, flat side into the cover. The vertical rod (with the spring) will then lock it in place
Old 05-31-2007   #8 (permalink)
Thanks for all your help.
Cheers
Darren
Clutch problem Caffeinated Twins Technical Talk 9 01-28-2008 01:26 AM
Clutch problem? Okie67 Hinckley Classic Triples 2 08-04-2006 07:29 AM
Clutch problem IrishJohnny Club Cafe 3 11-25-2005 10:11 AM
Clutch Problem Need Help def56 Twins Talk 6 08-03-2005 05:14 PM
