Old 05-30-2007   #1 (permalink)
So it's just about time for me to rejet for the first time. I have the '07 America, so bascally the same setup as the Speedy with 865 motor.
Fitted a beautifull set of Staintunes, pulled the top snorkel and installed the single K&N filter. AI removed and NGK Iridiums set.
I've been reading up on the jetting and checking out Pat's calculator. Recomendation is for 130 mains. If I'm not mistaken, stock = 120's.
I've also looked into the DynoJet kits, and recommendation there for stage2/3 (kinda what I've got is for 118's or 122's?
This kit however also comes with Needles, shims and springs.
What's the consensus around here? Just change the jets to 130's, or go with DynoJet kit and 122's?
Tx in advance for all comments
Do not TRY!
Do, or Do Not...
There is no try.
Saffer is offline   Reply With Quote
Old 05-30-2007   #2 (permalink)
Favorite Bike: 05 TBA
ErwinM's Avatar
Other Motorcycle: 1997 GT mountian bike :)
I just went with the jets. The rest of the stuff was /is still new. I went 130
Erwin
[ This message was edited by: ErwinM on 2007-05-30 19:26 ]
Erwin
ErwinM is offline   Reply With Quote
Old 06-02-2007   #3 (permalink)
Favorite Bike: o6' Blk Triumph SpdMstr.
speedblastr's Avatar
Other Motorcycle: 80' Blk Kawasaki KZ550-C1
I have the same as Erwin,except I ordered the TBS needles-1 shim on each from the advice of one of the members here at the forum,(needles)seemed to let the midrange throttle open up quite a bit.Easy to install. Follow Pat Dinqua's carb jetting Instructions for CVK carbs ,shimming Instructions too! If it interests you. He doesn't leave much out for the question I must say. :hammer:
"At times Ya' have to hold a candle to the Devil." ~06' Blk-SpdMstr~130/40,TBS Ndls.-1Shm.,3T,AI out,Plrs-Blmth,UNI,Th-Bi.-pipes
speedblastr is offline   Reply With Quote
Old 06-03-2007   #4 (permalink)
Favorite Bike: Speedmaster
Saffer - Go with the 130s and forget the jet kit. there's more there than you need and expensive (IMO).
Do you want to be the player? Do you want to be the string?
http://ratokc.com
rwright is offline   Reply With Quote
Old 06-03-2007   #5 (permalink)
I'm a firm believer in 130/1 shim/3-1/2 turns for most any setup that includes what you mentioned. If and when you drill the airbox or freak it, then things change a bit. But for the basic pipes/snorkel removal/UNI or K&N, that jetting setup is always gonna be close. Forget the dynajet kit. I won't swear to it, but i'm pretty sure it's more a money maker for them than a real improvement over stock jets.
Old 06-03-2007   #6 (permalink)
dardoonk's Avatar
Saffer,
I was ready to post when I read your question, but everyone has said what I wanted to. Do what they said. You'll be happy & have saved a few bucks.
I've gotten this far in life by refusing to act more than half my age, and I intend on continuing this way.
My Photos
'05 America- Works' suspension, Freaked, D&D's, 150 mains, 42 pilots, TBS needles, 1 shim
dardoonk is offline   Reply With Quote
Main Jets & Pilot Jets ggRAT Club Cafe 21 11-13-2007 08:52 AM
Windscreen for TBA midlifecrises Twins Technical Talk 0 08-25-2007 04:52 PM
Dynojet Jets vs. Misc Mikuni Jets ResearchRat T3 Sport / Touring Forum 21 04-05-2007 06:17 PM
SIDECAR ON TBA OR SPEEDY Brit26 Twins Technical Talk 14 09-16-2006 05:35 AM
More TBA Golfer's Beautiful TBA - PICS Ridge Twins Talk 6 07-09-2006 08:45 AM
