britishcustomsAnnitori DistributingSpringfield ArmoryMotorcycle.comRacerPartsWholesaleSportbikeTrackGearTriumphPerformanceUSATrident-Exhausts.comShopTriumph.comCycleGear.com
Old 05-30-2007   #1 (permalink)
RonD's Avatar
Other Motorcycle: Triumph Hurricane
Extra Motorcycle: several bsa,s
the problem with the stock bonny cap is that the seal is over tensioned when you screw the cap in, the ratchet drives the seal into the tank with to much pressure before it breaks loose.
just pull the cir clip and inside you will find a spring activated tongue that simply pushes into a slot, and breaks free when the spring tension is overcome.
unfortunately the spring is to powerful and drives the gas tank seal into the tank to far, the solution is to pull out the spring and reduce its length by simply grinding a fraction off it until the tension is at a sensible limit, if you take to much off stick the spring in your vice and simply pull it out a bit ..
Regards Ron
Hurricane pictured(Harry)
RonD is offline   Reply With Quote
Old 05-30-2007   #2 (permalink)
I just ditched the spring - no more embarrassing wrestling with the fuel cap at the petrol station, no leaks, no probs
Blackjacks '07 T100
  • Raask Minizoom Rak Straight
  • NARK
  • AI Removed
  • Procom ignitor
  • Thruxton Front Guard
  • D9 Layflat
  • CRS Carbs - 120 main, 60 Pilot, 2 Turns, 2 down on Needle Clip (7 Clip Needle), 14mm Float height
  • + Other assorted bits and pieces
Blackjack is offline   Reply With Quote
Old 05-30-2007   #3 (permalink)
Favorite Bike: '01 Bonnie
ggRAT's Avatar
Great ideas. Thanks, guys.
GO:904cc/-AB/-AI/K&N/Jets:140,45,-1.5,3mm/Predators/ceramic headers/180 rear/Ohlins/Works/520GXW+19Tx43T
SHOW:Pazzo levers/gaiters/Oberon pegs/Naps/new lights/SS braided cables/68 flyscreen,seat & cowl ... View Album
ggRAT is offline   Reply With Quote
Old 05-30-2007   #4 (permalink)
I just lube the seal once in a while.. never had it stick... then again.. I never over tighten either
zugspitz is offline   Reply With Quote
Old 05-30-2007   #5 (permalink)
Favorite Bike: 2006 Bonneville t100
after about 1500 mi worth of fill ups i never have a problem
unless i try to get it off without gloves....
Be Here Now.
WineWomenSong is offline   Reply With Quote
Old 05-30-2007   #6 (permalink)
On my scrambler, i tighten it up until it clicks once, and its still easy to open. Just push down like on an aspirin bottle and turn.
Not sure if the caps are different on various models
Scrambler06 is offline   Reply With Quote
Old 05-30-2007   #7 (permalink)
Favorite Bike: 2006 Triumph Scrambler
DrPat's Avatar
Other Motorcycle: 2001 Triumph Bonnie
Nice tip, that - lot of people have had problems with that cap! I think another way is to use a round section proper 'O' ring rather than the square section one on newer bikes. I swapped the round one from my 01 Bonnie to the Scrambler, and it solved the problem. Suppose one could slice the square section sealing ring down a little too.
Dr Pat
DrPat is offline   Reply With Quote
Old 05-30-2007   #8 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
Shortening springs does NOT change the spring tension regardless of application. Shortening a spring simply shortens a spring. In some applications, shortening the spring may work, but it would still be better to use a spring of the same length but one designed with less tension. :-D Spring wire diameter, # of coils per inch, and size of spring coil all play into determining the spring tension.
Larry
Larry
RedBird is online now   Reply With Quote
Old 05-30-2007   #9 (permalink)
5bassman's Avatar
There is no need to tighten it until it clicks. I never let mine go to the click. Just snug it down, it's not coming out! :hammer:
2005 Triumph Bonneville Black
5bassman is offline   Reply With Quote
Old 05-31-2007   #10 (permalink)
Favorite Bike: My Bonnie
Other Motorcycle: My other Bonnie
Extra Motorcycle: '98 FXD
X1 on bassman's comment
Shoot safe, straight and often...
BILLYSIM is offline   Reply With Quote
Some gas mileage results comparing easy and harder riding mecscc Twins Technical Talk 18 08-15-2007 12:26 PM
02 ST FAULT, EASY FIX THANKS TO THIS LIST harrya13 Sprint Forum 8 10-31-2006 05:40 PM
Gas cap is like child proof medicine cap and I'm kid rays323929 Twins Talk 14 05-14-2006 11:52 PM
Tricky gas cap (petrol cap) Strontium Twins Talk 22 02-24-2006 06:02 AM
Gas Cap Tight then...Gas Overflow bosoxrider Twins Talk 10 09-02-2005 11:22 PM
