hi, RonD
I bought the Givi XA600: works ok. Take care to adjust the angle of the screen to avoid buffetting, meaning you'll still feel some wind. I found out that bending the supporting rods at app. 7cm from the end towards the screen ( tough bstrds, use something to protect the finish) gives a complete free view on the instruments-just a tiny bend needed.
As can be seen in the pic there are two small bolts drilled in the black plastic bottom edge; since there are only two support points the screen originally tends to flap and rattle on the headlamp shell. Now it's tied down with two pieces of shoelace between the bolts and the headlamp bolts- hardly noticeable, no more noise.
Grtz, Thieu
PS: second pic is before tieing down the bottom- still have to insert the black plastic bolthead covers: adjust the screen, try out for best positioning-then cover up bolts. I had to pry the little so and so's out again a couple of times...
:-D
[ This message was edited by: greyplague on 2007-05-30 18:21 ]
