Hi Guys
Personally compared to all the problems I used to have with my old Brit bikes, even with my rose coloured glasses on, the tank seam doesn't bother me.
The main thing is that the tank is made of a good gauge of steel, unlike many of it's Japanese counterparts and it doesn't mount with that stupid center bolt bodge up, like old Triumphs.
Look how ugly the mountings on Sportsters are if you wanna see ugly.
Jon (UK)
