» Links |
05-29-2007
Powerbike Favorite Bike: '04 Speedmaster
Posts: 355 Other Motorcycle: I'd love an old Vincent
It says in the book that the chain tightness should be measured with the bike resting on the side stand, pushing up from the bottom toward the inside of the chain loop. If I do that it seems to be relatively loose. But, if I push it down (away from in inner chain it seems fairly tight. I lube my chain every 4-500 miles. If I ride (and I am not a lightweight) doesn't the chain need to be slack/loose enough when I am riding and hit a bump for example? It seems to me, if I read Haynes Manual and then just check the chain without trying to measure precisely, just a close visual, it seems to be just fine? Am I stupid? If it is too loose, are there noises I'd hear or anything else?? :???:
"The most happy marriage I can picture or imagine to myself would be the union of a deaf man to a knock out blind woman who digs motorcycles."
They have the chain spec figured out, so that if you measure by the book i.e. on the sidestand, from the place they specify, then your chain will be able to react the way it should in different situations.
I use a wooden ruler stood on the ground next to the chain, real easy to see when the chain deflects about 1 inch, which is a good place to set it
G
I just wanted to ride
05-29-2007
Yesterday I changed to a 17 tooth counter sprocket and in the process I cleaned and re-adjusted my chain.
I find the marks on both sides of the swingarm are hard to read so I use a micro gauge (you know the gauges for measuring thickness of shims etc) between the 2 marks on the photo. Just thought you might be interested as it is probably the most accurate way to ensure the wheel isn't skewiff.
BTW, thanks for the idea of the ruler for determining chain tension. I'll use that one myself now.[img]<a href=[/img]  </a>">
TOR longs slashcuts, Uni filter, Snork Rem and Drilled box, 130 mains, TBS needles and 1 shim, side gap iridium plugs, air @ 2.5 turns:
05-29-2007
No charge, either! However, your way of truing the back wheel, while sound in theory, assumes that both sides of the swingarm are exactly the same length, and that the adjusters are exactly the same and set in the exact same position on both sides, which in the actual world of motorcycling could be rare. The nifty little laser sight (expensive) or the mechanical version that draws a straight line between the rear and front sprocket, are a better bet. Having said all that, I just eye-balled mine and called it good. I think I may buy the tool, tho, for 25 bucks its not bad.
G
06-14-2007
Formula Extreme Favorite Bike: Triumph Thruxville :)
Posts: 546 Other Motorcycle: Another Triumph Extra Motorcycle: TR1 Chop/Bobber
Focus here in the UK do a laser thing for £9.99 and is magnetic. B&Q do them as well
06-14-2007
Grand Prix 125 Favorite Bike: Triumph America
Posts: 40 Other Motorcycle: Triumph 1974 Trident
Hello Tom
The method explained by Geoff ( Super sport) is spot on and very easy.
The other additional point of interest Re Chain Lube. here in Oz we have a lubricant called "Maxima Lubricants Chain Wax" it is excellent. Just warm the chain up with a 5 minute ride, liberally apply the Maxima Chain Wax and then let it sit for 10 minutes before you use it and hey presto. No Fling Off what so ever and it's good for around 1000 t o`1200 miles or just over 2000 Klms providing you haven't been in a lot of rain. If it's wet then you don't get quite the same distance.
Rgds
Gerry D
Ride it like you stole it, and keep the SMILE Alive.
Gerry D
06-14-2007
World SuperBike Favorite Bike: 2008 Victory Kingpin
Posts: 2,125 Other Motorcycle: 2006 Victory Vegas Extra Motorcycle: 2005 Speedmaster (Ret.)
Say Geoff, what ever happened to that NJ Tech day?
Kevin
Luceo Non Uro
NJ USA
06-15-2007
SuperBike Favorite Bike: 05 Black Speedmaster
"If too loose, are there noises I'd hear or anything else"
I notice the slop in the chain when shifting and adjust then. I also keep my chain on the loose side so as not to stress the chain or sprocket bearing.
06-15-2007
Nobody was interested enough to firm up a date and do it. I suggested a date and nobody replied.
I would do it if there was any interest, tho. Got a plan?
G
06-15-2007
on truing the rear tire, adjust the axle adjusters to get the rear tire centered between the swingarms. the marks may not be correct if the adjusters have been removed or changed.
cliff
2006 Bonnie Black
1980 Yamaha xs650
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Chain Tension |
TOMKRILL |
Twins Technical Talk |
12 |
05-16-2007 06:14 PM |
| Chain tension? |
dseely |
2 |
09-16-2006 10:24 AM |
| chain tension |
Gale_Gorman |
Twins Talk |
2 |
08-11-2005 03:29 AM |
| chain tension |
Modifications & Workshop Talk |
7 |
05-21-2004 05:58 PM |
| chain tension? |
12magnum |
Sprint Forum |
8 |
03-25-2004 04:01 AM |
