TriumphPerformanceUSAShopTriumph.combritishcustomsTrident-Exhausts.comCycleGear.comAdvanstarMotorcycleShowsMotorcycle.comBikeBanditSportbikeTrackGear
BikeBandit
Old 05-29-2007   #1 (permalink)
I'm looking for suggestions here...
I've got a Bonneville T100 with D&D silencers and just picked up a center stand which I attempted to put on this weekend. Unfortunately, since the pipes are after market, there are no mounts for the rubber stop, and after installation the center stand rests directly on the left pipe and the chain. As this does not seem like an ideal riding situation, I took the center stand back off the bike. Thanks to the forum BTW for the tips on using a wire hanger to attach the spring and for taking the sprocket cover off first, it saved me at least an hour of complaining and general bewilderment on how to get this assembly done.
OK, now back to the question... has anyone worked up a simple solution for properly setting the center stand with the D&D's installed?
Thanks in advance!
t.
tinc is offline   Reply With Quote
Old 05-29-2007   #2 (permalink)
I recently put a center stand on my thruxton with D&Ds and had the exact same dilemma. I actually ended up using the supplied rubber bumper that is supposed to be installed on the stock pipe, and the hard plastic extender that's the same size through it. I had to drill a 1/2" hole in the right spot where the center stand contacts the bottom of the muffler, and it took a little work and a flat head screwdriver but got the rubber bumper in the hole then put the hard plastic extender through it, making it impossible for the bumper to come out. It did seem crazy to drill a hole in a brand new 200.00 center stand, but at that part of the pipe it doesn't get hot enough to melt the plastic part. I rode about 50 miles at 80+, got off the bike and pulled the center stand down and the plastic was merely warm to the bare finger. Works like a charm, kept it clear of the chain and doesn't harm the pipe. Also, I bent the sidestand buffer out bit to clear the center stand when it goes down, and it's still catching the sidestand fine. I'll try to take some pictures today. I used a small bit to get the hole centered, then went to the 1/2" bit. The foot lever part of the center stand still seems plenty strong, and it's suprisingly easy to get the bike up onto the stand. Hope that made sense, attempt at your own risk though. I'd have hated it if I had ruined a brand new center stand drilling on it.
[ This message was edited by: Papasan on 2007-05-29 07:07 ]
2005 Thruxton
196? Chang Jiang 750
1991 Yamaha XT 600
59 Club Texas
Papasan is offline   Reply With Quote
Old 05-29-2007   #3 (permalink)
Loxpump's Avatar
Here's what I did. Very easy.
Center Stand Mod.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Old 05-29-2007   #4 (permalink)
hey boys, thanks for the info. i was thinking yesterday about a solution similar to papasan's but was afraid the plastic/rubber bits would melt on the pipe... good to know they don't. if you do get the chance, i'd love to see the pics!
t.
Center stand and D&D pipes TTRIDER Club Cafe 5 06-23-2007 08:37 PM
center stand or rear wheel stand? SlackCat Speed Triple Forum 16 05-08-2006 03:53 PM
Center stand and/or Swingarm stand or jack rprockey Hinckley Classic Triples 3 08-17-2005 07:21 AM
Paddock stand vs. center stand questions Solace Sprint Forum 6 04-01-2004 10:31 PM
Center stand and side stand wanted Sprint Forum 1 01-21-2004 09:38 PM
